stu stu stu stutter?
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › stu stu stu stutter?
- This topic has 19 replies, 9 voices, and was last updated 23 years ago by
Shypo.
February 10, 2003 at 10:15 pm #10881
my bit seems to stutter a fare bit now can someone help me to resolve this problam?????????
👿 LUKE 👿
February 10, 2003 at 10:54 pm #41416
you need to give more of an explanation, it stutters when it drives, when it gets a long way away, be more specific. otherwise we cannot answer your questions and its a waste of a thread
February 10, 2003 at 10:55 pm #41417
Have you changed the batterys in your handset latley?:shock:
Bap Bap Bap
February 10, 2003 at 11:00 pm #41419
did you remove the cripple cap from the car? after the removal of the cap the coil needs to be readjusted.
http://gtahh.web1000.com/
February 10, 2003 at 11:40 pm #41412
it could be the motor placement, i know my 3.0 stutters a fair bit
February 11, 2003 at 7:44 am #41394
Hi, it can be a radio interference problem.
I have a 57Mhz stuttering sometimes..it is a radio problem, the car get interference and start to stutter. Away from that zone the car is normal.
With 3 AAA battery in my controller I solved this problem, more powerful trasmitter beat interference on my tabletop circuit !Ciao
Efarel -
February 11, 2003 at 3:37 pm #41384
what car is it ? Look for the cripple capacitator, move the motor around (3 oclock position), give us more details and we can give you more details :clown:
57MHZ 2.6 Booster Trueno
February 11, 2003 at 3:41 pm #41382
Is there a furball caught in the axle?
Bap Bap Bap
February 11, 2003 at 5:12 pm #41364
efral how did u out 3 AAA batts in a 2 AA controller ?
👿 LUKE 👿
February 11, 2003 at 5:42 pm #41361
I recently bought a Skyline 27mhz and it stutters to. Mainly once it is about 1m or more away and when turning. I tried to remove stiffinh cap from the remote but the is not one there. I am going to remove the one from the car itself and change the aerial on the remote, and try adjusting the pot. Does anyone know what is the cause of this or what else I can do to fix. ?
February 11, 2003 at 7:42 pm #41353
what and where is the cripple cap ?????
👿 LUKE 👿
February 12, 2003 at 1:31 am #43900
please do not double post the_bit.
read in the tech section of this site before posting the same question
February 12, 2003 at 3:45 pm #41322
in the tech section search for cripple cap .. check the qfm website .. questformadness.com i think, it has it there
February 12, 2003 at 9:05 pm #41288
Efarel, is the change in power noticeable, does it over charge the car or what?
February 15, 2003 at 9:45 am #41121Quote:efral how did u out 3 AAA batts in a 2 AA controller ?
👿 LUKE 👿
I used an external battery pack with 3 AAA, good results, no extra heat but longer range and quicker radio response !
Efarel -
February 15, 2003 at 9:52 am #41116Quote:Efarel, is the change in power noticeable, does it over charge the car or what?
well I do not use it to charge my Shen Qi, I’m using a separate regulated Ni-Cd 2 Amp/h battery charger and I charge the bits for 5 minutes to achieve good 30/40 minutes of driving.
Even with a 5 minutes charge the internal battery doesn’t warm at all. The Lm317 regulated battery charger is doing a perfect job!
Efarel -
February 15, 2003 at 7:19 pm #41108
i got a 57mhz stutututttterrererer. annoying i tell ya.
February 15, 2003 at 8:57 pm #41106
man 30-40 minutes of runtime is HUGE, i wouldnt know what to do with that much BCG time lol.
my cars stutters only when it goes out of range or when the 3.0 gets knocked around, apart from that its sweet
February 17, 2003 at 5:15 am #41075
Efarel i made an lm317 charger and the most I can get is 20-25 minutes……
The world is mine
February 17, 2003 at 11:08 am #41072Quote:Efarel i made an lm317 charger and the most I can get is 20-25 minutes……
are you decharging your batteries before charge it again ?
Ciao
Efarel
