Supra = Nightmare!
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Supra = Nightmare!
- This topic has 7 replies, 3 voices, and was last updated 23 years, 2 months ago by
November 5, 2002 at 3:22 am #9464
I bought a Supra ages ago and the range has always sucked. So I thought today, I’d remove the PCB cripple cap and see if it improves…
…Nope!
So I opened the controller, no cripple cap in there, removed a blue wire though (just out of curiosity really) and it didn’t make it any better – it didn’t make it any worse (which I found strange) either – so I don’t quite know what that blue wire is for!?
I tried adjusting the POT – no luck!
So I’ve come to the conclusion that the chassis must have something wrong with it. I mean, it won’t go more then about 6inches before going out of range – and even then I have to be holding the controller’s antenna about 6 inches from the car’s aerial!
Should have sent it back yonks ago, but didn’t bother! My own fault. But I’m just puzzled as to what could be wrong! Any ideas?
November 5, 2002 at 4:11 am #16673
dude i got the same prob with mine its got not range or turning or battery life. i think its just the oldness
November 5, 2002 at 5:04 am #16678
check on the other side of thecontroller pcb there might be a cripple cap hiding there.
November 5, 2002 at 5:39 am #16681
6 inches. i would bust out the d.v.m. and check all your sh*t and conecitons. cuz it sounds like somthin on the control. is f**ked up.
November 5, 2002 at 11:59 am #16731Quote:Originally posted by GT-ahh on 05November2002
Way ahead of ya! Checked that when I had the controller in bits. No joy unfortunately.
November 5, 2002 at 12:00 pm #16732Quote:Originally posted by lancer_evo on 05November2002
Dude, if I knew what you were talking about for one minute, I think I’d try it :smiley1:
November 6, 2002 at 7:00 am #16773
is it the TX or the car, Chris?
Do you have another set non-Supra in the same freq, to use for testing?
November 6, 2002 at 6:47 pm #16853
Thanks Panda – I sorted it! You were right, it was the controller all along! You see, I did have another 47MHz controller but the aerial was stuck in the wound position – I couldn’t pull the aerial out. So I thought ‘doesn’t really matter, I’ve got the 47MHz controller that came with the Supra anyhow’. After racking my brains trying to get the Supra’s range up, and after reading your post, I thought its got to be worth me fixing that faulty 47MHz controller. So I did! And hey presto – good range :smiley1:
