suspension springs
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › suspension springs
- This topic has 9 replies, 3 voices, and was last updated 23 years, 4 months ago by
z-beam.
October 18, 2002 at 6:40 pm #9350
afx springs can be purchased from hobby and toy stores as apair for under $2. save all u other ozzies out there from wastin time with online shops and the like. unless u live in the bush ov course. still need a trimmin’ though. Also if u differ the length of the springs (longer on the right) u can fix steering problems.
October 19, 2002 at 11:59 am #15599
Yes I used the springs a while ago. The ones that hold the contacts on the track. Exept i got about ten for nothing.
October 19, 2002 at 12:00 pm #15600
I cut about 2 links off.
October 19, 2002 at 3:45 pm #15612
which shop z beam?
October 19, 2002 at 5:54 pm #15624
Just about any hobby shop which sells afx/ho slot cars.
October 22, 2002 at 9:30 pm #15824
some of the tires (small ones) fit the bit front rims as well.
October 23, 2002 at 9:59 pm #15903
Hmm I know its cheap but does suspension make a difference? No cars so far have really been made for off road, or carpet/lumpy surface. I dont think I need to worry about suspension when I only use my Bit Char-G on a flat surface, correct?
October 24, 2002 at 5:42 am #15913
But it look cool with coils, plus they work too.
October 24, 2002 at 7:03 am #15919
yeah hardersuspension springs help in keeping all four wheels in contact with the ground. less spin outs / better handling
also if you car veers to one side or turns better one way you can add a harder or softer spring on that side to fix it.
October 24, 2002 at 7:19 am #15920
certain lighters(bic i think) have hrd springs in them u have to strech the spring to permanatly lessen the diameter of it.
cain dont you race on tiles some times? adding medium length afx springs stops the car from flipping and loosing its orientation at every bump.
independant suspension is what its called. i only use the bar with springs because my skyline sits 2 mm off the ground.
