Tamiya TL-01 and M-03L
Home › Forums › 1/8, 1/10, 1/12, 1/18 – Discussion › Tamiya TL-01 and M-03L
Viewing 1 reply thread
    • #11864
      peedee
      Hey
      i was wondering if the MO3L the mini cooper new model uses the same hop ups as tl-01 ie tie rods, dampers, chassy parts etc…..
      thanks
    • #47518
      PandaBear
      Nup… the only bits interchangeable between TL01 and M03 would be:
      1) steering knuckles, rear hubs
      2) front stub axles
      3) kingpin screws
      4) wheelnuts? 🙂
      5) ok ok, same friction dampers too, if you’re that picky
      TL01 is 4WD with shaftdrive.
      M03 is a FWD.
      M03 is a close cousin of the FF02 (FWD 1/10 TC)
      but the M03 is a ‘mini’ and has shorter susp arms
      for the narrower stance (165mm vs 190mm).
      These 2 share the same chassis & drivetrain.
      There is a “spacer” that makes the chassis longer
      in the middle to suit either the full-size sedan,
      or the new M03L.
