The Bit Char-G Toolkit
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › The Bit Char-G Toolkit
- This topic has 24 replies, 4 voices, and was last updated 23 years ago by
November 1, 2002 at 6:11 am #9437
Yeah, i have solder station, drills, dremels, and loads more tools (you can never have enough)…but i aint gonna lugg all of that to race meets!
Impreza. The reason I use graphite lube is for many reasons. Firstly, lubes such as vaseline, ceramic grease etc., have drag which significantly reduces performance, and picks up dirt and dust. With these lubes there is a constant need to clean and re-lube everything.
With graphite lube, it is dry, so no dust or dirt, it has no drag, makes the motor rev higher, and you should be able to apply it once, and almost never have to re-apply it again.
November 1, 2002 at 6:31 am #16444
ive just got my whole electronics work bench…. theres alot of tools and stuff.
November 1, 2002 at 11:42 am #16481Quote:Originally posted by jamiekulhanek on 01November2002
If this is just graphite powder… be very careful. Sniffing in too much of the stuff is real bad for you, its like copier toner and all the old photocopier technicians often get emphysema (aka lung cancer) even the non-smokers.
I use teflon paint. Works better & can’t be wiped off as easily as graphite powder.
November 1, 2002 at 12:30 pm #16493
if teflon is non-stick how do they get it to stick to frypans?
November 1, 2002 at 9:31 pm #16506
GT-ahh, here you go.http://www.discovery.com/area/skinnyon/skinnyon970606/skinny1.html I knew Very High Heat was involved:smiley1:
Cheers, I’m off to eat some teflon pancakes:smiley5:
November 5, 2002 at 8:20 am #16696
No Pandabear, i don’t stick the nozzle up my nose and sniff. The graphite lube isn’t easy to wipe off, especially between the teeth. Also, i only use the stuff outside, and use it once in a blue moon. I reckon youre just as likely to get cancer from pencils.
Why don’t they make teflon gearsets for the cars?
November 5, 2002 at 8:23 am #16697
And the copier technicians played with toner like every day.
did you know coca-cola can give you cancer? -
November 6, 2002 at 7:35 am #16784Quote:Originally posted by jamiekulhanek on 05November2002
Dunno, drink enough of it but I don’t personally swim in the stuff! :smiley3:Guess if you feed much-too-much of it to lab rats, they’d grow cancer too.
I hear Coke makes a pretty good rust remover too, cheaper than Selleys RustFix. Don’t try gargling with Coke though…
November 6, 2002 at 7:39 am #16788Quote:Originally posted by GT-ahh on 01November2002
Teflon is a plastic compound. Its sprayed on to frypans and it cures on the surface like powdercoating.
Besides it don’t stick very well, I buy the best brands of cookware (Tefal, Meyer etc) and still the coatings only last so long before starting to bubble & peel. Overheating your pan will destroy the coating very quickly.
November 6, 2002 at 7:46 am #16790Quote:Originally posted by jamiekulhanek on 05November2002
Still unclear Jamie – you using graphite *powder* or graphite grease?
Ya, lots of things are carcinogenic these days, the cost ofmodern life. I’m totally suspect of mobile phones, its a prime source – I’d avoid yakking for hours. Its just a matter of which cancer gets you first… :smiley11:
November 6, 2002 at 8:05 am #16792
Graphite powder is sooo fine that it feel like grease but it is a powder, Just becarefull with the stuff in regard to your Bit char too. the powder is so fine it goes everywhere and if the stuff gets into the motor or the electronics it will kill you beloved car …US AF use a bomb that is based on this stuff to take out power station /substation 🙂
November 6, 2002 at 8:14 am #16796Quote:Originally posted by -ccw- on 06November2002
Yup, this stuff is pretty flammable… you can feed powered coal into an internal combustion engine (with different carburetion, naturally) and it’ll run too.
I use powered graphite to lubricate locks and my windscreen wiper rubbers. That’s what its usually sold for.
November 6, 2002 at 12:40 pm #16836
flammable ey, take sout power/substation ey, mwhahaha, i mean oh that really bad:smiley15:
November 7, 2002 at 4:20 am #16876
You cant put solid fuel into an ic engine…dodgy fuel is bad enough, and how would you ignite it?
It is fine powder btw.
November 7, 2002 at 9:49 am #16936Quote:Originally posted by jamiekulhanek on 07November2002
You cant put solid fuel into an ic engine…dodgy fuel is bad enough, and how would you ignite it? It is fine powder btw.
yeah, I know… but someone in one of the Unis did modify a current piston engine and fed it on powdered carbon. It had some kind of direct injection setup where the fuel was fed direct into the cylinder. Haven’t seen it on the showroom floor yet though – car that runs on pencil shavings!! :smiley2:
Carbon powder actually ignites easier than you think… eg take a teaspoonful and *blow* it over the top of a lit match. Do it OUTSIDE though… you’ll be most surprised. Come to think of it, BETTER NOT try it yourself; I’m a born pyromaniac and I’m used to putting out the fires heh heh heh (nobody saw it, nobody saw me do it, I know nuttin’!!).
Back in uni days, they’ve got engines that will run on just about anything. We even had one that you could vary the compression *whilst* it is running, that was quite cool. Nearly as cool as the gas turbine that idled at 50,000rpm – you can burn a lot of different fuels in this, from hydrogen to fossil oils.
November 7, 2002 at 10:27 am #16947
That variable compression engine sounds cool, it would be interesting to experiment with it. I have an engine that does that…model diesel engine.
Was the power output lower than a standard engine? Also i reckon the engine would wear out faster, cause burnt carbon is a bit abrasive.Anyway, were a bit off topic.
November 7, 2002 at 10:46 am #16950Quote:Originally posted by jamiekulhanek on 07November2002
haha, true… don’t need IC engines in the toolbox!! :smiley2:
November 7, 2002 at 11:41 am #16956
A bit fitted with a teedee .010
November 7, 2002 at 12:01 pm #16961
Someone did recently fit a tiny diesel engine to a Tamiya mini 1/32 monster truck and made it RC too… the pix are somewhere on the Net.
November 7, 2002 at 1:02 pm #16970
that would be cool. i have 1/32 slotcars which have nice bodies. subaru wrc and audi tt-r. tee dee .020
i was thinking of buying a second hand 1/10 rc car and fitting a 1.40 os engine into it. crazy but fun.
November 7, 2002 at 1:36 pm #16981
What’s a 1.40? As in 1.4cc or 1.4 cu-in?
If its 1.4cu-in, that’s about 20cc… that’s near weedwacker size and just a little bit too big to fit!!? Physically anyway…
Haha, I’m with ya – never possible to have “Enough” power!!
I love the OS Wankel engine too… one of these days I gotta go buy one for sourvenir. Its just too cool.
November 7, 2002 at 4:17 pm #17031
wankel!!! how cool must sound awesome too. cost alot in glow fuel.
you can never have enough power eh? yeah weve got some big engines, which would fit ( dont forget weed whackers have a huge flywheel etc, etc.) so i reck on with a bit of mod you could get a 1.40 cu in (23cc?):smiley3:
November 8, 2002 at 5:28 am #17065
Nah (and we’re waaay off topic)… 23cc petrol engines are already used in the big-muthas 1/5ths… they don’t actually give out that much power for the size/weight. They’re 4-stroke and they really purr nicely (no screaming like a crying baby) but the cars don’t look too fast because they’re so big.
We’ve got a huge track down here for the 1/5ths, but truthfully the 1/8ths which also run there will lap the place faster. But with 4WD, sponge tyres and 3hp 21 engines, you’d expect that too!!
At least with petrol… unleaded is only $1/litre
Vs $15 for nitro.OS Wankel is a glow engine… I hear someone put one in a SuperTen before. Guess there must be pix on the web somewhere, but can’t find them yet.
December 27, 2002 at 12:23 pm #17327
i have watever i find in my room on a given day.. or watever i make for myself (mini drivers)
lol..
December 27, 2002 at 12:27 pm #17328
i got a Cox .49 glow engine that im currently fitting to my Canned Heat (like can cars) i got it new for $20 with sum weird flying kit that i never built.. bought it for the engine.. i cant wait to get it runnin.. no reverse.. no brakes.. just2 minutesof pure drive.. heh heh
i hope it doesnt flip.. well sorta :smiley15:
-Peace
