TRACK HELP SOS – Update
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › TRACK HELP SOS – Update
- This topic has 7 replies, 2 voices, and was last updated 24 years, 5 months ago by
May 10, 2002 at 3:40 am #8896
I desingned a track, and started out with plywoood as a base and apinted it gray. Then on to the styrofoam, i drew the barrieers out that i would use on top of the plywood, but its impossible to cut! Its extremely messy and i am using a small blade, it is a very tough styrofoam and has a smooth compressed surface. What should i use to cut it? 🙁 🙁
May 10, 2002 at 3:47 am #13480
Hey Kevan!
Welcome to the forums. I encountered the same nightmare with my first foam cutting exercise. My workaround was a 32TPI (Teeth per inch) hacksaw blade.
However, having seen my messy results, other members on ausmicro.com advised that there is actually a product called a “Hot Wire Foam Cutter” available (about USD10.00). It cuts though the stuff like the proverbial hot knife through butter!
Cheers
Derek
(Fellow foam-cutting victim)
May 10, 2002 at 3:53 am #13481
Or you could use a jigsaw with the finest blade you have. Thtat’s what i plan to make my track out with once i get started on it. Dave
May 10, 2002 at 4:00 am #13483
Thnx, even tho i dont have a jigsaw ill ask me neighbors 🙂
May 13, 2002 at 4:02 am #13500
I don’t have the verbage done yet. But here is the promised photo catalog of the Foam Cutter. Complete with a diagram of physical dimensions.
http://www.angelfire.com/art/floydspalace/micro/cutter.htm
I post a small movie(in short order)of it in action…
-Floyd
May 13, 2002 at 6:11 am #13503
heh i’d probably be better off spending $10 and buying one instead of attempting to make one
May 14, 2002 at 1:56 am #13512
I want one, dammit! :smiley2:
Good news for people in Australia! Someone from Dymocks (the bookstore) was reading this thread and has emailed me. Apparently their big George Street (Sydney) store (the one with all of the art/craft stuff next door to Grace Bros) has hot wire polystyrene cutters in stock. Price is AUD26.90ea (approx USD13.00)and it can cut foam up to 4 inches thick
Yippeeeee!
Cheers
Derek
May 14, 2002 at 8:34 am #13519
*drools*
