Track Progress update
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › Track Progress update
- This topic has 19 replies, 6 voices, and was last updated 23 years, 3 months ago by
barto_85.
June 26, 2003 at 5:16 pm #11256
Work has made this project proceed very slowly, (that and my Lancer distraction), but although it’s still miles from completion, I have successfully run test laps throught the terrain today and it’s coming along quite well. I’m still using a two board setup and the biggest hold up was connecting some bridges back and forth. I killed off a lot of ideas along the way due to major difficulties, but it’s looking like it will be successful.
This track should look a LOT more realistic than my last. The pits will most likely return, I’m hoping for a pit wall with garages in the back. The overpass is dead, but we DO have HILLS!!! Lowered Bits BEWARE!!!
I’m basically done with the ground work. I just need to smooth the track out, paint and setup the barriers, but I’ve got some good ideas for all of them that have popped up along the way. I’m very excited, but don’t expect anything too soon.
June 26, 2003 at 6:40 pm #24945
post some pics when u can
June 26, 2003 at 9:02 pm #24951
excellent, sounds really good, can’t wait to see it, and your new lancer going around it.
June 27, 2003 at 8:31 am #24884
I’ll try to throw up at least one picture of where I’m at this weekend.
June 27, 2003 at 8:32 am #24885
It is all “plaster white” at the moment, so I’m not exactly sure how the pics will come out.
June 27, 2003 at 12:43 pm #24892
ohh well, give it a try anyway.
July 6, 2003 at 3:27 am #24476
I decided to wait on the pictures, because I’ve made HUGE steps towards getting the track completed. It’s painted for the most part, and has half of the barriers up. I’m thinking at MOST, it’ll be done towards the end of the month. It should be totally drivable next week though. The rest will just be detail.
July 6, 2003 at 4:58 am #24477
Cool!:)
July 6, 2003 at 3:50 pm #39467
excellent, can’t wait to see it.
July 6, 2003 at 11:05 pm #24455
M, what surface are you using for the track? Do you then paint this surface? If so how does it affect the cars handling?
Thanks mate,
Edited by – ph2t on 06 July 2003 19:58:47
July 7, 2003 at 7:43 am #24446
My origional track was on a hard wood type deal, almost like particle board but better. On this track it’s a plaster surface. It’s pretty textured, but I’m going for a WRC style course anyway, so I didn’t want it too smooth, but I did do some sanding. And finally I throw a few coats of Spray Paint. This doesn’t change the way the cars handle on the course and it’s important for the overall look.
One of the coolest things I noticed with my old track was how Dust affected the cars… after letting the track sit, it built up a layer of dust. They cars would do a few laps and then require a pit stop because dust buildup caused slippage. I thought it was a cool simulation of tire wear! 😀
If you are planning on building a track with hills, be sure to test the cars to ensure they can climb them… this was a major setback early on in my production, and caused HUGE changes in the design.
July 7, 2003 at 3:41 pm #24396
Have you got any shots of it yet? I’d love to see the work in progress. Sounds great.
July 7, 2003 at 4:42 pm #24403
I’m throwing up a quick shot of the progress. The walls on one side are, for the most part, complete. (Can you see in the picture that the walls are raised?)
The hills don’t look too impressive in this shot either, but I only had the room for one picture, so that’s it for now. You may also see the two trees are without leaves at this point (there will be 14 total trees when I’m done
If you look REAL close, you can see the first posted picture of my Lancer project. Detailed pictures will be appearing soon in the R.C. Mod Contest, but try to look at the differance in position of the Lancer vs the Impreza.
July 7, 2003 at 5:02 pm #24406
Thanks for the info M.
July 7, 2003 at 5:38 pm #24412
July 7, 2003 at 5:39 pm #24413
What do you think so far?
July 7, 2003 at 6:02 pm #24415
Very nice! You’ll have to get some video done of the track in action!
July 7, 2003 at 6:31 pm #24421
looks really good, how is it to drive on?
July 8, 2003 at 5:41 am #24217
I’ll have to find a way to get video
It’s awesome to drive on. With a 2.2 and boost, there are sections you CANNOT climb without the turbo button. 1.0 is fine the whole way because of the extra torque. The last turn on the technical side is actually a little too agressive. The cars actually bottom out on the hill if you take it wrong. I love it, because the your speed usually carries you through, but you can get thrown off course.
The walls, although beautiful to look at, have a rubber like plastic coating, that causes the cars to stick if you hit them. But… the track is wider than my last, and you’re not supposed to be on the wall anyway.
All in all… so far, I’m VERY happy with the overall result.
I’ll try to get a gallery dedicated to the track, so I can get some low pictures showing a better view of the actual terrain. It looks VERY flat in the pic compared to real life!
July 8, 2003 at 12:46 pm #24220
Sounds like the hill on my track. With a fresh set of batteries in the controller a warmed up 1.0 motor can make it up, but after a few runs it’s best with a 2.2 and a booster. look forward to seeing your track in action.
