Tx distance?
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › Tx distance?
- This topic has 19 replies, 9 voices, and was last updated 22 years, 4 months ago by
dgs73.
August 13, 2003 at 6:30 am #11800
I was just wondering what the Tx distance of Mini s are? Feet or Meters?
Edited by – Impreza on 13 August 2003 02:56:59
August 13, 2003 at 8:41 am #46828
feet for mine. i havent tested mine more than 50 foot but it seems like it has alot more range i just dont have a big enought track
August 13, 2003 at 1:26 pm #46833
Mines not much shorter than a real 1/10th scale car. 20 metres easy, 50 metres with good conditions!
Damn hard to see the car at that kind of range 😉
August 13, 2003 at 2:25 pm #46835
find the sweet spot and it will work better than new
August 13, 2003 at 3:05 pm #46837
Yeah mine has about 80-100metres of range after fixing it 🙂 By the time the car is that far away, it is prettymuch invisible.
August 15, 2003 at 6:32 pm #46869
Standard Mk.1 “Perfex” (aka JR Python, Acoms Technisport) TX
isn’t all that RF-powerful (due to legal restrictions?),
but it was the the same as what they supply for the
larger Kyosho RTR Readysets.Antenna on car also makes a difference.
Without the car antenna wire and the antenna unextended
on my Acoms Technisport, the range is about 4-6′.
With the TX antenna extended, its about 20-25′.For indoor use, that’s fine.
August 15, 2003 at 9:31 pm #46875
im scared to test the range cause when it goes out….it goes possesed…not good if u have a huge fet stack:D
August 15, 2003 at 10:18 pm #46877
Nah I don’t like experiementing with it either.. Then again I used mine at work… in out building which has good RF shielding (mobiles only work next to widnows etc) and it goes maybe 5m before spacking out into the walls!
August 18, 2003 at 9:05 pm #46905
GT-ahh got to love a runaway car:) 50 m should be good enough:D and 100 m is just insane:shock:. Jamie do you any delay in signal at that range? or is performance still responsive?
Edited by – Impreza on 18 August 2003 17:06:11
August 19, 2003 at 1:37 pm #46917
I had mine (complete with foam tyres, retuned supension etc) on the driveway the other night… It’s a short driveway and even then the speed and control can be interesting with the small size of the car.
In my defence it was twilight….
August 19, 2003 at 3:37 pm #46919Quote:GT-ahh got to love a runaway car:) 50 m should be good enough:D and 100 m is just insane:shock:. Jamie do you any delay in signal at that range? or is performance still responsive?
Yes there is a delay Impreza, however it’s only a few millionths of a second or so, so you would not notice anything 🙂
August 19, 2003 at 4:43 pm #46924
i get about 20 metres, then between 20 and 30m it developes a mind of its own, still (sort of) under control (likes to steer itself), outside 30m forget it…
August 20, 2003 at 5:48 pm #46955
Mine seems to go further than that, i could drive it down the street for ages before it was possessed by satan.
August 20, 2003 at 6:44 pm #46959
Anyone tried the option RX antenna booster sold
by Kyosho yet? Its a circuit board that replaces
your pianowire antenna, and stays under the shell.(Pianowire is a liability at chez Bear… it’ll
poke someone’s eye out before long. So I leave
it off…) -
August 21, 2003 at 3:37 pm #46969
yeah dident like it tho. my antena on my mod. z is the gpm mini antena works good and looks cool and its like the ant. on the remote 😉 .
August 21, 2003 at 4:37 pm #46976
though about getting one but dont trust the strength of reception. How good are those retractables, VR-4?(compared with stock.) Think I may have to get one. As long as the position can be varied to accommodate different shell sizes (and hence different aerial-hole positions on the shell)
Anyone semi-local have any spare stock Z aerials unbent, now that I think of it?? blackeye: -
August 21, 2003 at 4:49 pm #46977
Just make one from piano wire, I did, cause my other one got caught in my bag zipper and broke off.
September 23, 2003 at 4:33 pm #47325
tis what I did, Jamie… better reception due to it being 50mm longer too…
September 23, 2003 at 10:09 pm #47331
Mines 30cm long and can be very dangerous. I have poked my eye 3 times and my face to many to count.
October 17, 2003 at 7:54 pm #47485
yeah, mines about that as well. Range is up to easily 30m+ now…:D
