Tyre degree ?
Viewing 2 reply threads
    • #11899
      Jeff03
      With the modification of the mosfet and the motor from 4.2 my track is not adapted…. ( http://members.ausmicro.com/memberview.asp?user=jeff03 ) I have uncovered that for the miniz exists varies types of tire, they vary from 10C to 50C ( the 10C and 20C they are consumed with the use ). 😀
      I wanted to ask if you have news on the tyre of tomy…. the that colored… how much C have?
      P.S. I have the possibility to find rubber silicon of whichever degree… before trying I would want to understand which I must take… 😀
    • #47974
      ph2t
      I know that the colour tyre set has sticker tyres than the non-coloured tyre set. As to the C value I don’t know.
    • #48037
      Jeff03
      The tires have us a hardness of the rubber that comes normally expressed in “Shore”.
      This is an unit of certifyd measure and from the tests that I have executed, creed that the tires us “standard” would have to be of 50C.
      I have realized of the tires us to high grip, with silicon rubber from 30c.
      Now I must invent a system of front chassis with bearings in order to diminish the friction and to increase the weight front.
      At the moment I do not have photo but soon I make to see the photos you of my tires us greens… 😀
