underbody lights
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › underbody lights
- This topic has 14 replies, 3 voices, and was last updated 23 years, 2 months ago by
November 4, 2002 at 4:25 pm #9463
ive added “neons” to my rx7, they are the sort that are at the bottom of the door and are visible from the outside + light up the road…
http://www21.brinkster.com/gtahh/neon.htm
anyway have a squiz
November 4, 2002 at 6:34 pm #16655
why dident you just use 1 5mm super bright led. woked bad ass on mine cant see any leds but lights up under the whole car
November 5, 2002 at 4:59 am #16676
i wanted to be able to see the leds, like those neons u stick under your doors….only problem is they are abit wonky
November 5, 2002 at 5:36 am #16680
cool looks bad ass tho.
November 5, 2002 at 6:52 am #16686
i added light up washer jets aswell
u can see them here…
November 5, 2002 at 7:02 am #16690
are the light up washers just really bright red LED’s underneath the hood, or have you done somtehing special
November 5, 2002 at 8:12 am #16695
I put some body lights on my car like a month ago. There are 2 bright green LEDS powered by a lithuim batterie. I have also got 2 cell mod. Many bodies with body kits i moled on tight mufflers and sweet spoilers.
November 5, 2002 at 9:00 am #16700
Yeah i’ve been toyng with underbody lights. I ordered in some leds, cant tell you what colour yet…..but its gonna go off!! :smiley15:
November 5, 2002 at 9:08 am #16702
nah the LEDs for the washer-jets are SMD LEDs i got from dicksmiths (they are rectangular, with a round lense, about 3-4mm long) , i made a 1.2mm hole in the bonnet and stuck the lense through, ill scan the data sheet when i find it..
November 5, 2002 at 10:00 am #16709
i found purple yellow lime green red orange blue white leds at this store by my house
November 10, 2002 at 5:11 pm #17283
$30 US for 6 UV LEDs? ripoff. In aus they are $2.50retail which is ~$1.25 US
November 10, 2002 at 5:26 pm #17285
Lacer is just pulling his chain again.
November 11, 2002 at 12:22 am #17289
they go by color. red green and yellow are the cheepest white and blue are the most exp. look um up at http://www.radioshack.com and theres 3mm leds put out by street glow for havic lighting for real car’s in every neon. and lemme guess you dont think there bi colored led’s either?
November 11, 2002 at 4:13 am #17301Quote:Originally posted by GT-ahh on 10November2002
It *might* be possible… :smiley3:!!
There are some special LEDs made for “voltage”, not current. These have a little microchip inside (can be seen if you look closely) so you can connect them direct to a voltage source with infinite current (read 12V battery) without them blowing up, you don’t need resistors. Some also blink, or glow/pulse etc etc. They’re targetted at the ICE crowd so most of them run only on 12V DC.
Pricing on these aren’t cheap, they sell for A$5-10 each here in Oz even for the basic ones. Superbright & UV ones might be even dearer (as superbright ‘normal’ UVLEDs are already A$5-7 each).
ps: UV is bad for your eyes. You may be young and immortal now, but you may regret it bad when you get cataracts in 20 yrs time.
November 11, 2002 at 4:23 am #17302
i just read up on them and there filled with neon gas like a neon tube thats why there so expensive but the purple orange yellow blue and white at the most expensive.
