using tomy axles with oem bullet
Viewing 1 reply thread
    • #9146
      just got myself an orginal and a bullet. I tried switching the axles, however the orginal won’t fit on the bullet.
      After much studying, I found out that the axle on the orginal has a bigger metal shaft (the bar that connects the two rims).
      What i did was i use a small, very small sandpaper and sand the hole that holds the axle a little bit bigger.
      Make sure u don’t sand too much, or it’ll be too loose. Warning, after this mod the orginal axle on the bullet will no longer hold, cuz the hole is a bit bigger.
      Now, my oem bullet has all its things swapped, except the gear on the motor. The orginal motor has a small black gear and it won’t work on oems.
      So, almost everything is interchangeable between the two.
      Hope this is helpful.
    • #14746
      Thanks eyris this IS helpful stuff, since a mate and mehave startmaking alloy wheels (and i haven’t recived my bit’s yet).
      We almost have the wheels ready, but need to find some axles :smiley6:
