WARNING: Serious flaw in LXX Perfection Controller
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › WARNING: Serious flaw in LXX Perfection Controller
- This topic has 6 replies, 5 voices, and was last updated 22 years, 1 month ago by
January 17, 2004 at 8:20 pm #11270
Fellas, one day for no apparent reason my LXX perfection bit just stopped working. The main symptom was that the power LED on the controller turned off even though the controller was powered on. I also noticed that the batteries got very hot. There was a short somewhere on the controller PCB.
After a bit of stuffing around and testing with my multimeter I found the problem. The power LED leads were shorting to ground!!! This basically meant that the batteries were shorted and no power was going to the controller circuit.
Here’s a pic showing the LXX perfection controller PCB, the power LED is circled in yellow.
Here’s a close-up showing the source of the problem. Bloody crappy Chinese QA processes! arghhh!
To fix it I put a piece of rubber tyre to insulate the LED pins from the PCB.
All done. Now she works without any problems. I hope this helps anyone else that has had this problem….
January 17, 2004 at 8:39 pm #37875
nice one! my controller would indicate charge even though i’ve never used the charging plate! i just popped it open, and while i don’t have the same prob as you, i did find a couple of dry solder joins and even a part where the copper has lifted off the pcb!!:shock: easy fixed, but i worry about the kiddies without the tools to fix these little glitches. i’ve got one coming as a gift for someone, and i’m going to have to give it a thorough inspection before handing it over:8ball:
January 17, 2004 at 9:08 pm #37873
Yea I noticed serious drying out and other “funny” marks on the PCB when I opened it.
Also the PCB that has the boost button on it had a lifted track that broke when I removed it. Talk about crap quality….. At least the chassis is in better general working order….for now….ph2t.
January 17, 2004 at 10:23 pm #37871
Wel I suppose it comes down to the old saying, “You get what you pay for…”
January 17, 2004 at 10:35 pm #37869
very true…..
January 27, 2004 at 8:23 pm #37486
I noticed on all my BCG TX’s there lots of little chinamen fingerprints all over the damn thing, anyone else found this???
January 29, 2004 at 4:52 am #37443Quote:Bloody crappy Chinese QA processes! arghhh!
Those Chinese probably get 0.85$ for a car so it`s a miracle that cars work at all….
