Wiring problems
Viewing 2 reply threads
    • #8867
      Hey i was wondering if anyone had a picture or could take one and then upload it or explain it all to me of the wiring for the bit charg. Iam trying to solder back the 3 wires that came off of the solder. Left, right, and one more that i don’t know of so if anyone has a picture i can look off of, i could solder it back. Please that would be greatly appreciated. I also would like to know if anyone knows what the V+ is on the board. the
      f = front
      b = back
      l = left and
      r = right
      but i don’t know what the V+ is. Thanks, Dave
    • #13331
      Hi Dave!
      I’ve JUST finished photographing the board and adding some labels to the images. Check out this new galleryand let me know if it helps.
      WARNING: People on dial-up connections should note that the first image is *BIG* at 474KB in size
      Oh…. to actually answer your question…. V+ is the red wire from the battery.
      Cheers
      Derek
    • #13494
      Hello,
      to complete the wiring informations, I’d like to add that together
      with the red (V+) wire, in the same spot are also soldered the
      “other” single wires coming from both the steering magnets. The wires
      can be distinguished from the ones going to the L and R pad because
      they’re “stained” with white paint.
      All the “tiny wires” are very difficult to solder: you may find that
      even if the wire is firmly soldered, it apparently does not make
      contact: this is because they’re painted with an almost invisible
      insulating coat, that you may need to scrape off…
