Xspeed + Overland
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › Xspeed + Overland
- This topic has 8 replies, 7 voices, and was last updated 20 years, 8 months ago by
mini-g.
March 16, 2005 at 11:11 pm #12589
Can I put just the Xspeed motor into a stock Overland so it will go faster? Do I need to upgrade anything else for it to work? Do overlands break easily? Thanks.
March 16, 2005 at 11:34 pm #58974Quote:Can I put just the Xspeed motor into a stock Overland so it will go faster? Do I need to upgrade anything else for it to work? Do overlands break easily? Thanks.
You can put Kyosho X-Speed, PN S05 and Atomic Stock Motor into your overlander without any power-up modify. But don’t put any i-waver motor, they can be bure your PCB.:D
If you like to upgrade your X-Speed, you can modify it with ball bearing motor case.
March 17, 2005 at 4:15 am #58980
yup i second kens statement about the i-waver x-speed and x-speed pro motors, they will burn out the fets of any stock kyosho mini-scale car…
you had that experience as well hey ken?
March 19, 2005 at 8:42 am #59023
I have try i-waver X-Speed and X-Speed Pro before.
I test both for 2 mins on my MR-02 stock and modify.
The i-waver X-Speed is very very very slow and very hot on the PCB.
The i-waver X-Speed Pro is not design for stock car, although you put it on power-up modify car, it still slower than Kyosho X-Speed with stock car. Also very hot on the PCB.The summary is they are very very poor!
Edited by – ken_wyleung on 19 March 2005 03:43:34
March 19, 2005 at 8:02 pm #59026
i have used the x-speed with my fetted car (6×2 stack) and it did get extremely hot. you could see sparks in side the motor as well…
May 5, 2005 at 1:18 am #59466
The PRO is not all bad, but quality is sure to be variable… The Sydney boys can attest to how well one can run (with 5×2 7389) and a 9 tooth.
I would think in a better tuned car/chassis the performance would be quite good. Certainly Plasma Dash comparable.
May 5, 2005 at 6:51 pm #59477
Im running The pro in the Iwaver with a 10tp powered buy a 2×3 stack of 7317 s…
I have not had a problem with it except the wires are flimsy and break of easy….It dose +50 in its speed range…
May 5, 2005 at 8:13 pm #59480
my x speed pro is a bit odd… does nt have any go at all for some reason. Comparable to the X speed (K) in an unfetted car (12t pinion too). So I agree Aaron; the quality is most definately variable. Was running mine with the older (and still running strong after almost 2 years!!!
) IRF7389 fets. Maybe it’s an Iwaver X speedwith a pro sticker on it? Still pulling high 50s with the rebuilt P.D. though -
June 18, 2005 at 11:41 am #59643
so how did it end up seatbelt?????
