Alu. chassy
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Alu. chassy
- This topic has 15 replies, 6 voices, and was last updated 22 years, 8 months ago by
VR-4.
June 27, 2003 at 9:14 am #11235
well im 1/2 way there instead of makeing a tub chassy i just made a pan. its on the rather heavy side still trying to figure out what to make to hold the rear axle in. so far everything else is good.
i was gonna make 2 holes and just put small ball berings in it and then just reassmble the axle in it but that wont let me change the gears 2 easy. but like i said from the start this isent gonna be a race car its just gonna be a look at my sweet ride.
June 28, 2003 at 5:36 am #24932
the germans have made an alum chassis…. it has a fat rear axle and bearings…
June 28, 2003 at 5:00 pm #24935
i got 1 its on the hefty side im trying ta cut weight but test chassy 1 got bet to easy. time for titanum or magnesum
June 28, 2003 at 10:01 pm #24850
y not make it out of alloy?
or carbon fibre?if your going to those lengths
June 29, 2003 at 2:20 pm #24821
carbonfiber would be to weak. how big the weave is on the fiber and how meny holes are in the chassy would be really weak. all it would need is a nice head on smack into a wall and its tost
June 30, 2003 at 6:18 pm #24604
CF is damn strong, much stronger than plastic, so i doubt it would break.
I have alloy sheets at home so im guna make a pan chassis now .
I was thinking of using thin PCB material but i dunno if i cn get it thin enough.
June 30, 2003 at 6:20 pm #24605
prob is that when you drill the holes to mount the parts and for the charge jacks the weave is so big it take alot of the strength out of it.
June 30, 2003 at 6:31 pm #24608
any body know about cf molding? i am getting sheets in varying thicknesses, is it lighter than alu? i know it’s damn hard but when heated can be bent to shape.
June 30, 2003 at 6:46 pm #24611
you can mould it like fibre glass aswell i think,
June 30, 2003 at 11:36 pm #24618
dude the BCG isnt exactly gonna endure alot of abuse.. Carbon fibre would be fine.
July 2, 2003 at 4:22 pm #24663
Thats what i said, the kinetic energy of these things is very small compared to bigger R/C.
Managing to scratch a BCG is pretty hard with normal use so a CF chassis would be fine. -
July 2, 2003 at 10:36 pm #24673Quote:any body know about cf molding? i am getting sheets in varying thicknesses, is it lighter than alu? i know it’s damn hard but when heated can be bent to shape.
CF is not “molded”, it needs to be manufactured into the complex shape you want, or just into plain flat sheets.
To make it, you need a mold which is laid with the fibre. Then you inject (“impregnate”) the fibre with liquid dope under high pressure and high temperature. Its a lot like fibre-glassing, except you need an oven big enough to fit your mold into – check out the size of a Formula One workshop’s oven!!
Once cured into the shape of the mold, there is nothing else you can do to shape it. You can cut it, sand it, saw it etc, but you can’t thereafter reshape it with heat or pressure.
Contrary to popular myth, CF is not “strong” per se. Its structurally very stiff in certain dimensions, but it is also brittle and can crack/break if you stress it wrongly.
And most mythical of all… CF does *not* have a visible fancy weave pattern! The real graphite threads are BLACK! The fancy pattern you see on the top is merely printed on a plastic laminate, to give you what you’re expecting. 🙂
Be careful too… remember its carbon fibres.
1) when cutting/sanding, you must have RESPIRATORY PROTECTION.
People who don’t will die a long painful death like Smokers!
2) CF conducts electricity… fibreglass doesn’t. -
July 2, 2003 at 10:39 pm #24674
btw, meet “SSG” (Silver Surface Graphite)…!! 😀
July 4, 2003 at 3:29 pm #24721
You ruined it for me panda…..lol
July 4, 2003 at 4:09 pm #24724
i just gor the blue weave cf chassy for my fusion
July 8, 2003 at 7:38 pm #24253
this stuff i can get is for theraputic innersoles and maybe they are b’sh!t!ng the customers as they use ovens and a vacuum molding machine to shape it.
thanx for the info panda, i dont think i trust my respiritory protection(decent gas mask) enuff to risk the slow painfull death.
