Antenna Mods
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Antenna Mods
- This topic has 9 replies, 8 voices, and was last updated 23 years ago by
Cranga.
January 23, 2003 at 6:56 pm #10700
Has anyone tried the antenna mod where you wind it around a cotton tip and get this cool looking twirly antenna?
What does it do for your range? Worse/better/same?:question:
January 23, 2003 at 7:10 pm #42653
cotton tip? thats pretty thick!
is that on the car or the handset?
I have done the car one with dual cat 5 cable core’s that increases the range by about 3 meters, but a pain if you have 2 cars racing different tracks in a large room with the same frequencies.Bap Bap Bap
January 23, 2003 at 7:13 pm #42646
Yep I’ve done it…
It didn’t really change the range. I’m pretty sure that’s because the lenght of the antenna didn’t change, although with the antenna standing a bit shorter, theoretically it should decrease the range slightly.
But I then decided to un-curl it and unknot the antenna under the PCB to extend the antenna hoping for a extra boost in range… No real noticible increase tho… maybe 10cm or so for the stutter free range…
btw, I think that the antenna is glued onto the plastic PCB cover on some of the compacts.
Hope that helps
January 23, 2003 at 7:58 pm #42649
it’s really just a cosmetic mod “makes it look COOOOL” like adding decals or some thing
March 2, 2003 at 11:26 pm #40139
yeah i found that the antenna was glued (looked melted) to the pcb cover
Compact Char-G S2000 27MHz (not mods yet)
March 2, 2003 at 11:46 pm #40134
your antenna was seriously glued to tha PCB??
whoa that sux, my PCb was glued down but i popped it off with a thin plate scrwedriver. all my BCG pCB clipped off easy, but my compact ones :angry:—-
March 3, 2003 at 12:04 am #40120
yeh compact ones are made glued down …
57MHZ 2.6 Booster Trueno
March 3, 2003 at 1:19 am #40116
yeah it really PISS me off how they are glued down but then the bits from japan the PCB covers just jump off :angry:
March 3, 2003 at 4:42 pm #40094
o well you can open them fairly easily, just be careful 🙂
March 3, 2003 at 5:51 pm #40088
its good that they are glued doen cause one of mine has a tendancy to jump off in a horror smash..i think its bent or something
custom shells, mods and tips
