Batt and motor limits
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Batt and motor limits
- This topic has 19 replies, 9 voices, and was last updated 22 years, 2 months ago by
Shypo.
January 16, 2003 at 9:15 pm #10069
While at dick smiths i saw 1/4 AAA 6v batts and 1/4 AAA 9v batts so that would be like a 5 cell bit and a 7.5 cell bit so do you think this would blow the engine or would it work fine the only bad thing about the batts is that they are alikines not recharges
January 16, 2003 at 9:19 pm #43176
i think the motor would blow as some people have had problems with a 2 cell blowing a 3.2 motor
January 17, 2003 at 1:26 am #43137
hehehe, those teeny alkalines have many cells inside them, and they have such high an internal resistance, that the voltage would drop and you would have a very slow car indeed.
The world is mine
January 18, 2003 at 4:54 am #43056Quote:the only bad thing about the batts is that they are alikines not recharges
:smiley2:uA -
January 18, 2003 at 6:55 pm #43039
so you are saying you can recharge Alkalines?
January 18, 2003 at 10:48 pm #43036
Yep.:)duracells can be, energisers are probably the same too. They charge up to about 2/3 of the previous charge. So if you got 10 hours out of a new battery, then charged it, youd get about 6 hours the next time, four hours the next time, maybe two hours the next time….. then youd thro them away.
:clown:uA
January 19, 2003 at 11:46 pm #43001
Interesting about the rechargeing alks but will any one test the motors to see how much voltage they can whitstand??
Also would say a 1.0 be a motor designed for a higher voltage but beause the bit only gives out 1.2 volts it goes slower or is it just made diffrently??
January 20, 2003 at 1:18 am #42997
Most likely designed differently ( I havent checked yet) The 1.0 would take more voltage because it probably has a higher resistance. A 3.8 would have less windings of thicker wire inside and would therefore have less tolerance to having more current shoved down its throat by increasing the voltage. I intend to test a couple of motors to destruction (and rewind them??), but I want to get a proper lab power supply first so I can properly record the results. Give me a couple of days…watch this space.
uA :question::question::question: -
January 20, 2003 at 2:09 am #42995
It may also have something to do with the timing of the motor.
The world is mine
January 20, 2003 at 8:04 pm #42939
What exactly do you mean by “timing”
:question::question:uA -
January 22, 2003 at 5:28 am #42836
would the motor be able to take more voltage when running free ( no load ) than when it is running a car around??
January 22, 2003 at 4:48 pm #42791
Yes…kind of. At a given voltage, the more loaded the motor is (meaning the slower it spins) the less back emf is produced. Less back emf will allow a higher effective voltage accross the motor resulting in higher armature current and higher risk of burning out.
The two extremes are….
1. High voltage, no load – motor spins quickly and uses very little current – little risk of buning out.
2. High voltage, high load – motor slow or stopped and draws higher current. This is the highest risk of burning motor out.
The guys that are ‘multi cell’ing their bits should be careful not to drive the car with the rear wheels locked, either by holding them or stopped against an object head on. This causes high ‘locked rotor’ current and this is when the chances of motor burn out is highest if the battery voltage is too high for the motor.Hope that makes some sense
January 22, 2003 at 7:04 pm #42746
thanks does any one know if a 2.4v 1/4 AAA recharg batt is avilable coz that would rule
December 20, 2003 at 4:36 pm #38574
The 2 cells can blow 3.2’s because they have sh*ty reliability
Eat right,exersize…die anyway! -
December 24, 2003 at 12:51 am #38388
From what I’ve read on other forums, people have put up to 12 volts through the tiny motors. It killed the motor rapidly, but other sources say they’ve put around 9 volts through them with no problem. The next question of course would be the amps. MicroAmps might need to correct me on this, but I think Voltage and current work with other aspecs to bring the value of “wattage”, witch would be the most aplicable measurement of how much punishment the motors can take. So the question may not be about volts or current individualy, although I’m sure they both have a maximum value that’s capable of being pushed through the motors. It may be a question of watts, witch is a value calculated with volts, current and some other stuff.
I use perfection 3.8’s, 4.2pros, and 4.2kings. I mainly run with dual cells w/ fet modded boards and 3:1 gears. I’ve only replaced 1 x 3.8 in the last 6 months. I run the cars an average of once a week for about 2~4 hours.Edited by – HACHI-RYOKU on 23 December 2003 20:23:51
December 24, 2003 at 1:52 am #38385
I was wondering where this thread came from.. I hadn’t noticed it. But looking at the dates in the header. jan 2003.
What we need to do is get all the different colour and style motors and destruction test them.
Well maybe not destroy them all, just one…
but run them all through a standard dyno type test.Voltage / Current / Load / RPM type graph.
I can think of a way of making a tiny brake dyno
that can put a standard load on the motor.After knowing this data on a graph it would take the guess work out of the motors. probably take some of the fun out too. 🙂
December 24, 2003 at 4:07 am #38381
Someone already made a pretty nice chart with many motors. I haven’t seen anybody refer to it so I was wondering if it’s coshier or not. I know some of the pros know what I’m refering to. Is it ok to post that stuff here? It’s from another forum. And I know some forums don’t get along, and don’t appreciate certain other forums info being posted on theirs. If it’s ok, then I’ll post it myself. If not, then I understand.
December 28, 2003 at 5:00 pm #38195
no problems on this site hachi, we are freindly intelegent evolved humans here. no nazi dictators rule this site.:shock:
December 28, 2003 at 6:11 pm #38194
post it man, fuck ’em!
December 29, 2003 at 5:46 am #38188
OOII. I’ll do it as soon as I get a little more time.
