do led kits drain batteries faster/slow down Z??
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › do led kits drain batteries faster/slow down Z??
Viewing 21 reply threads
    • #11675
      hey guys
      happy b day aaron
      i was just wondering if the led kit for the mini z s slow down the car or drain the batteries??
      can some1 please help me out
      and any1 who wants to sell bodies please contact me:smiley16::evil::shy::smiley2::approve:blackeye::p:blush::dead::D:question::clown::):sad:
    • #45700
      Shypo
      they dont seem to slow the car down.. they dont drain the battery cos they have there own.
      Go Fast, Be Free with Low CC
      Undisputed Post Pimp
    • #45703
      thanks bud
    • #45704
      Shypo
      No probs.. only downside is they add weight and cost a fair bit, lucky i got mine from Bithed:D
    • #45714
      jazza_1984
      my LED kit weighs next to nothing, probly 50 grams at the omst and they would all be the same… the added weight is not noticable at all it is so miniscule… and lights sets fullly assembled are only about 25 to 30 dollars so they are cheap as well… i hghly recommend them i think that they are great
      Ţŭ₣₣Кı??
    • #45715
      Shypo
      Yeah true Jazza, Do you have the Kyosho one?
      i have the kyosho one and it has like 4-6 lights and batterys. 50g may only seem a little bit but in a car which only ways like 500G thats 1/10th of the things weight.
      I leabe them out anyways cos i cant be bothered to drill the lights thru so i can put them in.. maybe one day when i wanna put my car on show but for now its there for racing and thrashing around the place.
    • #45760
      jamiekulhanek
      Jarratt, dont forget 50 grams is about 1/4 the weight of your whole car. Thats like adding say 400kg to a normal car…….
      The current that LEDS draw is so tny that it is almost insignificant to affecting the runtime of your car.
    • #45951
      jazza_1984
      it weighs 10 grams i took it in to work and piut it on the industrial scales 😉
      shypo it is not kyosho lights set… it has 4 leds, two white, two red it was a custom job…
      yeah i have it in my mini z that is SUPPOSED to be for show, but ends up finding its way to the race track more often than not because for some reason, my friend and i cant work it out… the thing flies… uses same batteries, etc as my race z… dont understand, but anyway…
    • #45973
      FreeLoader101
      why dont u guys just make ur own lite kits?? or do these like have special functions or sumthin.. like that full lite kit for Bit Char-g with the turn signles and brake lites?? if not then lites are hella easy to do..
    • #45978
      Shypo
      the lights I have do the following
      -light up full beam when going forwards
      -brake lights are doim when driving and become bright when stopping
      -work off the cars battery
      -have 6 different Led’s
    • #45979
      FreeLoader101
      ok.. so basically they’re really simple:dead:
      it would be fairly easy to do turn signals.. just build a blinker that turns on certain lights when ur servo is powered.. i have a blinker.. i just need to figure out a way of making it work.. next would be brake lights.. u’d need a switch that will turn them on when no other power is felt from the motor.. my skool has those.. next is reverse lights.. just hook em to ur motor.. mabey with a delay timer so that if ur just braking they dont come on…… low and high beams would be cool too… i wouldnt mind gettin my hands on one of those little full light mods that sumone made for Bits.. only made for Z’s instead.. ne one know who built it?
    • #45995
      jamiekulhanek
      My car has Ultra bright white headlights, and rainbow underbody neons, which look sick. One of my headlights is failing tho which sucks.
    • #45996
      FreeLoader101
      y dotchu fix it?? ima have crazy green and yellow headlights.. then i have these LEDs that look clear but glow red.. so its perfect for altezza.. i need 2 more tho.. and i need sum clears or blues for reverse.. if i end up makin sum crazy turnsignals and such i’ll make a tutorial for everyone.. prolly next year tho.. when im back in skool
    • #45997
      jamiekulhanek
      Cause im guna make a new set with 7000MCD leds….
      Im also buying a new shell just to mod, its guna be…
      A green Toyota MRS with carbon hood (cause its a cheap shell)
      -with Green underbody neons that beat to subwoofer.
      -Superbright LED headlights/tail lights
      -Multicolour neon tubes in the back window and front grille.
      -Lowered Body
      Aaaaaannnd im guna *try* to make a stereo, just gotta find ok speakers.
      What else do u guys think i should do to my shell??
    • #45998
      jamiekulhanek
      Whatabout an electronic BOV simulator??
    • #46001
      FreeLoader101
      BOV=???
    • #46005
      Shypo
      Blow Off Valve = BOV
    • #46006
      FreeLoader101
      ohhhhh i c…. whats a blow off valve??
    • #46007
      jamiekulhanek
      Blow OFF Valve
    • #46008
      jamiekulhanek
      its used in turbo cars to release excess pressure.
    • #46010
      FreeLoader101
      ohhh is that the sound u hear when the turbo goes? that “PTWooo” sound? ok.. i gettit
    • #46015
      jamiekulhanek
      Like when turbo cars change gears the go ‘PSSHHHHTTTT’
