gear help
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › gear help
- This topic has 7 replies, 5 voices, and was last updated 22 years, 7 months ago by
DaveF.
March 7, 2003 at 1:45 am #9932
Hi everyone one of my bit’s is having a problem with the gear that conects the engine to the axel. its actually loose and as a result the gear some times slips. it only ocurs when i put from forward to reverse quickly. how do i fix this problem? get some new gears or can i tighten the gear thing???? any help would be great.
Thanxs:)
March 7, 2003 at 1:59 am #38302
do u mean the gear on the axle?
becos if u r talking about that then just glue the sucker into place—-
March 7, 2003 at 2:36 am #38306
if you mean the middle gear amybe turn the pinion the other way around so the flat bit holds the gear on?
March 7, 2003 at 2:48 pm #38320
The gear that is connected directly to the motor is called the pinion gear.
The Gear on the axle is the axle gear.
The geat that send the power from the motor to the axle is called the idle gear.
Which one do you think is the problem?
DaveF! 👿
March 7, 2003 at 9:20 pm #37746
the idle is gear is the problem.
the thing keeps on moving around.
sorry about the lateness of the reply. -
March 9, 2003 at 7:17 pm #37544
then flip your pinion around so its back to front and then put the idle gear on, thats way it doesnt have much room to move around
March 10, 2003 at 7:51 pm #37610
I know that this is a little off topic… but I have seen some people using glue or putty to “seal” in the rear axle. Does this work to keep the car tracking a straighter line?
Edited by – zensx on 10 March 2003 14:51:31
March 10, 2003 at 8:26 pm #37615
that wouldnt do anything becos the axle doesnt turn the car.
