How to go faster?
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › How to go faster?
- This topic has 20 replies, 10 voices, and was last updated 23 years ago by
DioXidE.
January 12, 2003 at 7:22 am #10001
Hey guys,
My skyline is lacking in speed, What can I do to make it go faster? I’m thinking of a dual cell mod + a 3.0 Motor… Is there anythign else I am missing? I’m lookin for accel mainly so should i get the hillclimb gear set as well? -
January 12, 2003 at 10:06 pm #43437
If youre lookin for accel i suggest a 1.0, its the equivalent to 1st gear in a car where a 3.0 is more like 5th. Apart from those mods theirs not much else you can do, except maybe soft tyres which will give you slightly better traction.
There are three types of people in the world, those whocan count, and those who can’t.
January 12, 2003 at 11:10 pm #43436
dual cell by itself will increase the accel + top speed dramatically, give that a try then see if u need a faster motor
January 12, 2003 at 11:52 pm #43431
what motor do you have at the moment, you might want a 2.6 if ur after more acceleration that top speed or if ur after pure accleration id reccomend the 1.6
January 13, 2003 at 10:02 pm #43367
I have no idea what motor I have at the moment…
I have a compact CHar-G 40mhz white skyline.You recommend I try a dual cell mod 1st?
January 13, 2003 at 10:25 pm #43362
youd have a 2.2, and a dual mod is the best way to boost your speed.
January 13, 2003 at 10:27 pm #43359
that or if you arent to good with a soldering iron then go out and buy yourself a KIT racer and steal the motor, get the ornage capped end one.
read more about KITs in this forum and you will understand—-
January 14, 2003 at 2:39 am #43354
How much are the kit racer?
Can I use the batter from them for a dual mod and the high rpm motor from them? -
January 14, 2003 at 4:22 am #43348
DioXidE, the KIT racer topic is pretty well covered elsewhere here, but as we are both newbies I’l give you a rundown.
You can use KIT racer motors, batteries, tyres and heatsinks in a compact charg. If you have a dual cell mod you can try useing the bitracer gears (sliglty modified) in your bit as well. Otherwise they won’t work very well because your bit motor just doesn’t have enough torque to run the (relatively heavy) bit car with such high gearing.
you can get KIT racers for about $24 from Kmart or Toysrus (just look in the hotwheels section). If you get one pick the RPM or KPH/MPH set. They have the 2.6 motor in them (which is faster than the 2.2 motor in your compact charge). Also look at tradingdirect. They have faster motors, gear sets and different tyres, all of which are great basic mods and are easy to install. -
January 14, 2003 at 6:45 am #43343
ok, i’ll look for a kit racer as i can get all the cool parts from em 🙂
January 14, 2003 at 10:14 pm #43323
just make sure the motor bottom is orange:)
January 15, 2003 at 4:10 am #43940
thanks shy…
January 15, 2003 at 7:15 pm #43291
Pls don’t get your hopes totally inflated though… the Orange=2.6 isn’t spectacularly faster than the Yellow=2.2 motor.
Drag both side-by-side and you’ll barely see the difference. Even after 8′ the 2.6 car is less than 2-3″ further ahead.
January 17, 2003 at 4:54 pm #43117
Ok, I bought a 3.0 Motor from trading direct,
Now i think i’ll get the gear set…
SO I can get a bit of torque and accel…. -
January 17, 2003 at 5:15 pm #43121
how much was the 3.0 from trading direct ??
January 17, 2003 at 6:21 pm #43108Quote:how much was the 3.0 from trading direct ??
About $20, with around $5 postage, which in that postage you could include a body or gear set.
Bap Bap Bap
January 17, 2003 at 6:22 pm #43109
which is what i did! they has some spare auto modellista bodies, so i snatched them with my 3.0, totaly cool set, for very cheap!
Bap Bap Bap
January 18, 2003 at 12:16 am #43063
O ok well bit_charg_oz@hotmail.com has them for $18.50, just letting you know.
January 18, 2003 at 10:56 pm #43037
The guys at bit_charg_oz are doing an excellent job. We should support the local guys that are having a go. Work out the $$ conversion on the cost of a BCG or accessory before you buy off ebay and compare it with these guys prices first.
Happy customer :approve:
January 19, 2003 at 12:43 am #43021
wonder who the guys behind the scenes are barelll? LOL yeah theyre good and i buy a fair bit of my stuff off of them.
The world is mine
January 20, 2003 at 4:47 pm #42977
hmmmm i have NO idea :blush:
57MHZ 2.6 Booster Trueno
Mini Z Castrol Supra + all mods (Coming)
