Questions on dual batt bits
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Questions on dual batt bits
- This topic has 10 replies, 9 voices, and was last updated 22 years, 10 months ago by
Shypo.
February 2, 2003 at 7:33 pm #10852
Hi everyone. I am new to the forums and was quite fascinated by the dual cell bit built by Prabbit. I am in the process of building my own two cell terror. I was wondering if I could get some specs on his dual cell
bit? Also what is the switch type thing mounted on top of the PCB cover?
I have a WRX microsizer that I got for Christmas. This is going to be my guinea pig since I really don’t want to ruin my prized bit (acura NSX)
Is wiring the cells in series the way to go? I have heard of other methods.
Lastly, how long do you have to charge it for? Do I have to build a custom charger or will my controller have the cajones to do it? -
February 4, 2003 at 6:25 am #41862
dual cells are in series…and yes you have to build a custom charger..i removed the charger port from my controller and attached it to a 4AA cell holder…i carge my dual NiCd bit for 90-120sec…
http://gtahh.web1000.com/
February 4, 2003 at 2:32 pm #41856
has many people done dual nimh? Or mainly nicad ? I reckon ill be doing dual nimh, i should get around to doing it one day soon lol :clown:
57MHZ 2.6 Booster Trueno
February 4, 2003 at 7:51 pm #41805
Guess it depends what cells you can get, more than anything else.
Doesn’t seem to be anyway of getting original Tomy nicad cells apart from scraping one off a BCG or KIT.
February 4, 2003 at 8:03 pm #41810
PM Pcain, he will tell u what to do.
The world is mine
February 4, 2003 at 8:50 pm #41793
I used 1/3 AAA NiMH cells (120maH) in mine (AU$6 ea from battery world). The stock ones are only 50maH, are physically bigger and weigh more so not much point using them. Here’s a hint: if you can’t get the solder to stick to the battery contacts scuff it up a bit with some sandpaper etc beforehand.
February 5, 2003 at 2:28 am #41717
Yeh Ive done a dual internal NiMh cell bit and with a 3.8 in it, it flies. Heaps of fun, it drifts real well too, on the right surface.
Go for it, you will enjoy 🙂
uA -
February 5, 2003 at 2:37 am #43799
ever tried a dual batt bit with a drift axle micro_amps?
have fun………….
February 5, 2003 at 2:37 am #43700
have fun………….
February 5, 2003 at 2:44 am #41715
dual batt with drift axle = pointless…lol
you dont move. just spin.
check out my thread i got some stuff for sale 🙂
February 5, 2003 at 2:39 pm #41704
fair enough then, i will be going dual nimhs, wheres the best instructions for doing them inside the chassis ?
