Reverse problems
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Reverse problems
- This topic has 25 replies, 7 voices, and was last updated 23 years ago by
iusionary.
February 22, 2003 at 12:38 am #10920
I have one of those Compact Char-gs (the honda s2000) and the reverse dosnt seem to work very well. It dosnt move and when i give it a push to get it going it then goes in reverse. Basically i have to push start it to reverse the car. Forewards works fine.
Can this be fixed?
and also i live near brisbane, are there any places that i can get char-g bits? like tires, new shells, motor, suspension etc etc..
February 22, 2003 at 1:15 am #40628
welcome to the boards i||usionary
the problem i am guessing you are having is that the gears may not be meshing properly and therefore they wont spin freely. the way to fix this is just slide on the gears, make sure the middle or idle gear spins freely and then u should be fine. if this doesnt work then i am guesing the problem is the motor postion so just wiggle the motor around a bit until it works properly. hope this helpsas for the bits and peices u r after the only place to buy them is online
Edited by – Shypo on 21 February 2003 20:17:42
February 22, 2003 at 1:46 am #40627
oh ok thanks ill try that 🙂
could you list a few australian sites that might sell parts?
February 22, 2003 at 2:04 am #40626
if that boesnt work see if the problem occurs without the gear…ie see if the motor will reverse freely..my 3.0 motor wont go forwards without a push..
February 22, 2003 at 5:07 pm #40618
try taking your motor out and putting it back in.
For bit char-g stuff contact bit_charg_oz@hotmail.com , website coming very soon 🙂
57MHZ 2.6 Booster Trueno
February 22, 2003 at 5:26 pm #43638
ok thanks, i also have problems with my steering, i saw on one of the videos i downloaded from here where 2 cars race on davef’s track, and they turn really good, mine wouldnt be able to turn those U turns and maybe not even the 90deg. turns : do i need new steering or something?
February 22, 2003 at 5:30 pm #40614
is there anything under the car where the steering is (metal peices) that may be effected the steering magnet ?
The only thing to fix steering is usually to open it up, and that is quite difficult the first time.
Get in there, clean it up, watch out for the steering spring tho, clean the magnet, place it in the middle of the holder, that should make a difference
February 22, 2003 at 6:21 pm #40606
cool thanks, i realised it was just my bad driving 😯
I just needed to back off the accelerator a bit to make those tight turns.
…another newbie question (sorry if im boring you)
How do i get at the battery pack?, only thing ive done it take off the axel:p
February 22, 2003 at 7:10 pm #40607
i wouldnt advise mucking around with the battery… but basically you pop off the pcb cover and lift up the circuit board…
be really careful tho..cause those tiny steering wires can snap and they are a bitch to solder back together..http://www21.brinkster.com/gtahh/
February 22, 2003 at 7:23 pm #40608
is there a difference between the compact char-g and the bit char-g? are parts for both interchangeable?
February 22, 2003 at 10:28 pm #40613
yep, they’re one and the same. Compact Char-G is the local name for them, while Bit Char-G is the Japanese name. And yes the parts are interchangeable.:smiley2:
February 23, 2003 at 8:56 pm #40595
the tire set helps heaps..
soft tires on the front, hard on the back=tight turning
the tireset comes w/three types of hardness tires so you can do fine tuning. very handy for perfecting track skills. build a track at home,only poor bits race on dirrt-e floors. dust sticking to tyres affects steering severely as well. -
February 24, 2003 at 4:01 pm #40562
yep all parts are interchangeable, they are the same thing, just been given a new name, but only 2 cars under the compact cahr-g range, compared to about 20 under the bit char-g name.
February 24, 2003 at 7:55 pm #40542
where can i find bit-char-g parts? im starting to get sick of my “stock stadard” s2000 :p
Compact Char-G S2000 27MHz (not mods yet)
February 24, 2003 at 9:12 pm #40529
http://www.ebay.com
http://www.hlj.com
http://www.toyeast.com
http://www.tradingdriect.com.auany of those are sxweet for BCG parts
February 24, 2003 at 9:13 pm #40528
bit_charg_oz@hotmail.com for local (Australian) or if you want ordering from overseas over the net, toyeast.com
February 24, 2003 at 11:14 pm #40495
u can also find sum parts, quite expensive tho from local hobby shops
February 25, 2003 at 11:40 pm #40429
mmmm, 3.8 motor
$20 AUD excluding postage!
who’d of thought these things would be so expensive!
February 26, 2003 at 1:18 am #40408
man thats a bargain, alot of people ask up to $25Au for a 3.0 motor!!!
February 26, 2003 at 8:38 pm #40367
i paid au$25 for a kit racer just for the 2.6!
February 26, 2003 at 9:29 pm #40356
whoa man thats a little steep..
i bought my KIT racer for $16:D—-
March 1, 2003 at 3:47 pm #43601
these things cost more than i thought!
March 1, 2003 at 9:07 pm #40180
it can be an expensive hobby but its all worth it in the long run
March 1, 2003 at 9:37 pm #40178
its all about fun….not money
March 2, 2003 at 11:39 pm #40133
exactly, just imagine how many hours fun you get out of them, worth every cent 😀
March 10, 2003 at 2:29 pm #37570
I had the same problem with my compact Char g. I just gave the chassis a good clean, vacuum, got the tweezers out and pulled out any hair from the axles etc. Then I just ran it quite a lot using reverse more than forwards. Could just be a temporary problem. Mine works fine now.
