RPM
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › RPM
- This topic has 28 replies, 11 voices, and was last updated 22 years, 6 months ago by
mastercool bowker.
January 21, 2003 at 2:42 am #11595
I ve seen on some websites, most websites, that bit char-g motors go at an amazing 22,000 RPM (2.2motor). Is this accurate or is it more likely to be 2,200 (2.2)?
January 21, 2003 at 5:08 am #44385
Nah thats true. 1.0=10,000RPM 2.2=22,000RPM 2.6=26,000RPM 3.0=30,000RPM.
You are probably thinking that it is impossible for a motor to do those speeds? Maybe a car engine, but small engines rev really high.
The world is mine
January 21, 2003 at 1:53 pm #44386
yep jamies got it right, 22 000 rpm, gotta love the speed, hehe 🙂
57MHZ 2.6 Booster Trueno
January 21, 2003 at 8:56 pm #44399
is there any reason all 3 of my cars would be
seeming to lose rpms?? first off, quick as…
lately tho, they tend to be a fair bit slower.
tried greasing the axle, rotating the motor( that
“3 o’clock” position works, but only for a little while, it seems),new AA’s in the charger, etc.
Any ideas???? -
January 21, 2003 at 11:09 pm #44401
Did you do anything to the bats (NiCD’s) in the car?
Impreza :smiley16:
January 21, 2003 at 11:27 pm #44402
How old are the cars, David?
Nicads do have a finite life, probably around the 500-cycles mark (maybe even less given our quickcharge abuse). If they’re well-used cars then perhaps you’ve charged it 500+ times already and the cell is getting tired.
January 21, 2003 at 11:28 pm #44403
But no fear!
Just buy a $24 KIT Racer car from KMart/TRU etc and that’ll score you a new Tomy cell and a new 2.2 or 2.6 motor.
Instant tuneup kit! 🙂
January 21, 2003 at 11:39 pm #44404Quote:Nah thats true. 1.0=10,000RPM 2.2=22,000RPM 2.6=26,000RPM 3.0=30,000RPM.
Motors can rev high as there’s no reciprocating parts, its just a balanced spinning axle vs a piston engine whose bits move up/down. Double the rotational speed and it becomes 4X the forces on the crank/conrod/gudgeon-pin/piston.
That’s free running RPMs anyway… when the motor is unloaded.
January 22, 2003 at 5:16 am #44410
does any one know the RPM of the wheels when running ????
January 22, 2003 at 4:55 pm #44425
You can work that out by dividing your motor speed by the gear ratio you are using.
eg micro B3.0 is 30,000 rpm / 9.86 = 3042 rpm at the wheels
BitChargUK have a page where all the ratios are worked out -
January 22, 2003 at 5:03 pm #44426
also QFM have a page for all Bit Char-G and Bit racer axles and there RPM to there corresponding pinion and tyres aswell i think?
January 22, 2003 at 5:41 pm #44428
[/quote]
[/quote]
Thats right pandabear! just like the marvelous rotary engine! Invented by the top bloke Professor Wankel
Bap Bap Bap
January 22, 2003 at 6:01 pm #44429
that was meant to be w a n k e l.
i guess you cant say wank in these forums! how about any other swear words?Bap Bap Bap
January 22, 2003 at 6:12 pm #44430
Oddly enough, two of the cars are less than 2 weeks old, and would be lucky to have topped the 100 charge mark. The Nicads have had nothing done to them (in reply to Impreza) but maybe they are abit weary.
January 22, 2003 at 10:44 pm #44438
??? What are the freq’s of the cars? Just a hunch, you seem to know what you are talking about so I will not ask you if your axels have a large hairball stuck to them;)
Impreza :smiley16:
January 22, 2003 at 10:58 pm #44439
lol, never underestimate the hairball 😉
January 22, 2003 at 11:15 pm #44441Quote:that was meant to be w a n k e l.
Rotary engines still have to move their rotors, they just move in an eccentric orbit. The crankcase is like a figure-8 and the triangle rotor shifts back-n-forth as the crank rotates.
Nah, the only true rotary engine is a gas turbine. Pure simple spinning action: 50,000 rpm is their *idling* speeds!! :shy: Played with one at uni before… quite an impressive gadget.
January 22, 2003 at 11:24 pm #44442Quote:i guess you cant say **** in these forums! how about any other swear words?
****! what are you ****ing trying to do to this ***ing forum my dear *****??! Whatta *****, don’t be a ****ing bad example to all the **** kiddies reading this ****site.
(Yes, I deal with ****ing Truckies a lot. :blush:)
January 23, 2003 at 2:47 pm #44445
I think we’ve seen from the ‘What age are you’ posts that there aint many ‘kiddies’ here:)uA
January 23, 2003 at 3:18 pm #44446
in reply to Impreza, the cars are 27MHz and 40MHz, so yes they are Compacts not Bits, not that that should make a major difference.
And yes, lose crap and hair, etc. doesnt even get a chance to accumulate!! Im guessing maybe something real small may have worked its way inside the motor, if thats possible. -
January 23, 2003 at 3:36 pm #44447
nice to know im not the only thirtysomething chasing these cars around!!
January 23, 2003 at 6:11 pm #44454
Compacts should not make a diff. I didn’t know that they came in 40 MHz? Having 2, 27 MHz in the same area can effect performance. Plus sometimes the 27 MHz cars can stumble a bit:( Maybe try the cars in different rooms. Try the basement if you have one???
Impreza :smiley16:
January 25, 2003 at 4:56 pm #44532
compacts come in 27 and 40, microsizers come in 27 and 49 other BCG comes in 27, 35, 45 and 57
January 26, 2003 at 1:11 am #44539
Nice to know that there is a 40 Mhz bit option out there:)
Impreza :smiley16:
January 26, 2003 at 7:42 pm #44554
the 40,45 and 49 cars pretty much all interfere which reallllly sux. i dont understand how a mini Z can run on like 27.145 and another on 27.348 or whatevr it is and there is no interference:question:
January 26, 2003 at 10:28 pm #44569
Sounds like a question for Panda or micro Amps?
Impreza :smiley16:
December 20, 2003 at 4:27 pm #48846
im a kid
December 20, 2003 at 4:28 pm #48847
8 1/2yrs old and…ah, never mind.
December 20, 2003 at 4:32 pm #48848
lazboy, go to ‘www.tinyrc.com/qfm/racing’
It tells you what speed ur wheels are spinning with each motor and with whatever gears.
Eat right,exersize…die anyway!
