SECCEEDED in drifting!!!!!!
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › SECCEEDED in drifting!!!!!!
- This topic has 21 replies, 8 voices, and was last updated 22 years, 7 months ago by
GT-ahh.
March 8, 2003 at 10:35 pm #9940
today i was at my friend’s place and we we’re playing with my bit, and i wanted to give drifting one more shot. so we tried to look for a really smooooooth surface, and all we could think of is his marble table. at first i tried it with the tires, i knew it wouldn’t drift or slide at all, i just wanted to see how much grip it had. then i took off the tires and tried it, it slided a bit but not enough to drift properly, it was more like dougnuts…i didn’t want to give up cos i had a feeling that it was capable of drifting, so we tried to think of something else. then i saw on his shelf a bottle of windex, saw i tried that, and it did work, but it needs some getting used to. you’ll have to counter-steer, and after u spray the windex just wipe it once gently. i did this without any mods on my car, still the stock 1.0 motor. can’t wait and see wut kind of results i’ll get when i get my 2.6 motor and dual cell.:D
March 8, 2003 at 11:26 pm #39869
lol, i never thought of that…my dusty wooden floor and a dualcell 2.2 is my setup….
March 9, 2003 at 2:44 pm #37687
Try running your car backwards with no tires on a dusty floor. I only have a 3.0 and it works but with more speed it wiould work better. Just get used to the strange driving technique!:8ball:
March 9, 2003 at 5:40 pm #37689
There’s a document somewhere on driving techniques. Very informative read. I’ll try and track it down.
My tracks give drift with 2.2 and above motors. It’s great with a booter set.
DaveF! 👿
March 9, 2003 at 6:42 pm #37674
satin varnish……
DUSTY FLOOR! no respecta!:shock:
180 degree turns are easily acheivable with the right tyre combo on a generously satin varnished COFFEE table. i can even whip my trailered Bb around 120 degrees if at full speed when turning av a look at the beast
http://groups.msn.com/bitchargoz/paintingmods.msnw?actionShowPhotoPhotoID53
chemicals and dust might simulate what u desire but deep down you Know the truth “this is NOT a mini-z”
go buy a booster and a tyre set and then you can really drift!!!:smiley2:
March 9, 2003 at 7:57 pm #37549
I have a hardwood floor that gets dusty from time to time. I have been able to hold a drift for almost a foot. I have been playing with different tire combinations and am getting better at it.
March 9, 2003 at 8:21 pm #37553
varnish-masonite= half assed drift which is ok
my track in other words lol
March 9, 2003 at 10:43 pm #37557
180 degree turns are not drift…thats spinning out…my dual cell can do perfect 360s and keep going if i take the tyres off
March 10, 2003 at 7:46 pm #37609
It is truly a difficult thing to do with a car that has such a small wheelbase. I noticed earlier today that my stretched chassis car is much easier to drift. Maybe the secret is in the wheelbase.
March 10, 2003 at 9:41 pm #37632
or maybe you need a mini-z….anyways its harder to drift on wooden floor after its been raining because the humidity makes it sticky….:D
March 11, 2003 at 2:24 am #37648
definetly need a mini z and sum poliushed concrete:smiley16::)
March 11, 2003 at 5:06 am #37652
Olive oil works!
But that’s just the wog in me!
March 12, 2003 at 10:44 pm #37363
LOL ph2t, i tried using baBY powder and that made my slide but i had to clean the car out for about 4 weeks afterblackeye:
March 12, 2003 at 10:53 pm #37368
Don’t make your floor into a skid pan. buy a bit of board, give it a barrier all round the edge, then put the oil on that. No mess on the floor, and you don’t have to add so much oil to the board after it’s first few uses. The oil helps keep the board in tip top condition too. =o)
DaveF! 👿
March 12, 2003 at 11:04 pm #37374
dont ur tires stay all greasy and crappy?
and dont u get bits of oil all inside your car and stuff:dead:—-
March 13, 2003 at 4:08 am #37381
They’re just clones, to die for the cause……..:evil:
March 13, 2003 at 7:09 pm #37398
GT: spin-out eh?
isn’t drift the art of controlled spin out?
the secret is custom drift tires! tomy drift axle as you gotta know by now sux, the idea is good but hard plastic tires don’t grip at all.copy the cut out idea and hack some grooves into a pair of hard rubber rear tires, try to keep them neat and even and make sure to use a real sharp blade.
“begun the clone war has”
-yoda-without clones i wouldn’t have had as much fun.
March 13, 2003 at 10:03 pm #37411
I think the KIT racer has a tire set (white) that is like that already I think. Tread running around the tires (fromt to back groves).
DaveF! 👿
March 13, 2003 at 11:41 pm #39861
yeah they re ultrahard…and yeah you’re right z-beam drift is a controlled loss of traction.:Dbut its abit hard on a car with no proportional throttle controll or steering.
March 14, 2003 at 1:08 pm #37313
That’s what makes it so cool when you pull it off. :approve:
DaveF! 👿
March 14, 2003 at 3:33 pm #37317
Hey GT, just wait till my propo controller is finished then you’ll have some serious drifting action! :smiley2:
March 14, 2003 at 9:47 pm #37258
dave the drift axle has groves side to side.
i did start with the same hardness and pattern tyres as the white kit tyres (black enertech) and then cut the ridges in.
da drift rig:
http://groups.msn.com/bitchargoz/paintingmods.msnw?action=ShowPhoto&PhotoID=50
