Spring Suspension
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Spring Suspension
- This topic has 92 replies, 12 voices, and was last updated 22 years, 11 months ago by
Barrelll.
January 22, 2003 at 7:52 pm #10693
Has anyone done the spring suspension mod on QFM’s site?
What kind of performance increase does it actually give?
January 23, 2003 at 3:35 am #42694
Yes i have,
It does make your turning circle grater and the car spins out less but if the springs are too long the car wont turn about half a spring is more than enght also if the springs are not even it will drift to one side fun if you have more than one car because if ya break anything on the front end ya can be in real trouble but it is a fun mod and i think adds looksCompactChar-G 40Mhz S2000 range mod, spring suppention
January 23, 2003 at 5:39 pm #42666
i used the springs from an old afx slot car set i had lying around…
http://gtahh.web1000.com/
January 23, 2003 at 7:02 pm #42652
By greater turning circle you mean a tighter turn, or a wider turn?
Lazboy, use punctuation mate. It helps us understand what your trying to say without having to re-read five times. Cheers.
DaveF! 👿
January 23, 2003 at 7:42 pm #42648
Lazboy: do you mean that the turning circle is smaller? (Heh, looks like DaveF beats me to the punch again…)
Springs from a slot car set… hrmm… I was actually thinking of cutting up a spring from a spring loaded pen…
January 23, 2003 at 8:11 pm #42644
Locksmiths also have very small springs, in lots of sizes. I’ve read the springs form the slot cars (some makes anyway) fit really well, ubt you still have to cut them to size. I’m planning on asking the local locksmith tomorrow or early next week. I’ll let you all know how it goes.
DaveF! 👿
January 23, 2003 at 8:12 pm #42643
Cool, keep us posted!:D
January 24, 2003 at 4:50 pm #42591
i have done it and the first time i did i cut the springs to short, make sure you only cut a couple of rings off if you are using AFX springs
January 25, 2003 at 7:18 am #42431
I believe 3 and a half rings off an afx set is the best amount.
January 25, 2003 at 1:35 pm #42423
How can i get springs in. i can hardly put the front wheelset on without springs.
👿 LUKE 👿
January 25, 2003 at 4:50 pm #42417
you have to dissasemble the front end first. for most of these mods i seriously recommend you check out http://www.questformadness.com
January 29, 2003 at 4:27 pm #42202
So, can someone who has done the spring mod please inform the rest of us if the spring mod makes the turning circle tighter (smaller diameter circle) or bigger (larger diameter circle). Cheers.
DaveF! 👿
January 29, 2003 at 7:34 pm #42194
DaveF: How did the locksmith thing go?
January 29, 2003 at 11:13 pm #42176
my turning circle seems tighter
January 30, 2003 at 4:19 pm #42154
I agree with Shypo and Craz on this one… ive been choping little bita at a time of my AFX springs, and found 3 rings removed doesnt affect steering, but did tighten the cars turning circle. Thing is now, ive got to put the springs in my Compact, as i did the mod on a Cyclona… doh!!
January 30, 2003 at 4:41 pm #42140
Just swap the springs over to your favourite car if they’re perfect already, then start again on your less favourite car.
DaveF! 👿
January 30, 2003 at 4:47 pm #42139Quote:And just to beat the prices on the web I’ll sell each spring for Aus $1. mwahahahaaa.
Well, do they fit perfectly? Without needing to be cut?
blackeye: I went to my locksmith yesterday and he basically told me to nick off…
January 30, 2003 at 4:52 pm #42138
Any spring you get will need to be cut to length from what I can gather, even the ones fro the UK site. Has anyone purchased the springs form the UK or QFM site? Can they confirm if they’re pre-cut?
Edited by – DaveF on 30 January 2003 12:19:20
January 30, 2003 at 8:48 pm #42129
i believe the ones from QFM are just AFX springs lol, $1 each spring would be better than $8 for an AFX tune up kit
January 30, 2003 at 9:39 pm #42112
Oh, maybe I should charge $5 per spring kit. I could even cut them in half first.
Who wants one? :smiley2:
DaveF! 👿
January 30, 2003 at 10:11 pm #42108
$5!!!! im happier with the $1 a spring idea, i’ll take 4 thanks:)
January 30, 2003 at 11:10 pm #42098
Shypo. I’ll do you $1 springs, because yo’ve been a great help t me thus far, and I’ll need your help again on how best to fit the damn things. :blush:
Everyone else – $5 per spring set (for front of BCG car) inc postage.
DaveF! 👿
January 31, 2003 at 12:06 am #42096
thanks heaps man, dont worry i will be glad to help in the future:D:D
if you want u can send me 1 or 2 of your bits and i’ll fit the springs for u—-
January 31, 2003 at 6:36 am #42087
um guys sorry but unless you have some weird batch or somethin those afx springs will be pretty damn useless (bar cosmetic) if you cut em in half. for starters only some springs are identicle on both sides=differing tension.the perfect length is a imposible cos there are different uses (as in the real deal). have a search in the old pages for info on susp. springs
i’ve fitted 5 bits with spring suspension one of which is hard custom springs from a lighter.dont bother with this one, a double or triple layered spring does the same.
shypo have you had a go painting the sprigs? looks sweet if done well.
one more thing, the cut uncomplete end of the spring should be wound around the nuckle so that you have even contact between the steering plate and the tops of the springs when assembled and pushed down.:8ball: -
January 31, 2003 at 6:47 am #42084
my s2000 has the hard suspension and a nimh cell.the only other thing i’ve done to it is lightening the chassis and shell by shaving layers with the stanley. on the digi scales it weighs in at 22.0 grams. those springs make a difference, i swear that tomy should have made the wiring a tiny bit sturdier and had spring suspension as a stock hop up like gears e.t.c.
January 31, 2003 at 3:26 pm #42068
$5 a spring set? Already cut?!? What if I want ones for different heights? Tell you what, I’ll cut the springs myself and you can drop the price back down to $1 a set… (Saving on the labour costs… Plus you’re still making an obscene profit)
Z-beam: What difference do the springs make? And what do you mean by double or triple layered spring?
January 31, 2003 at 3:51 pm #42067
Cutting the springs in half has already been done, but they’d still need further trimming anyway, to get them to the optimal height for your driving style.
I was kind of joking about selling them, but as $5 is still $3 cheaper than on the web, $5 it is.
DaveF! 👿
January 31, 2003 at 8:52 pm #42031
i just dipped my springs in paint and let them dry, then peeled them off the paper, painted that side which had paint torn off now i have red springs and golden springs:)
February 1, 2003 at 5:12 pm #42001
Z-BEAMS VARIABLE SPRING SUSPENSION MOD:
when you first start making spring suspension there are bound to be a few too short to do any thing with. so what i worked out is that by cutting a spring at the desired lenghth you can wind the other usally wasted half (or shorties) on to the cut end of the spring. just make sure you have springs with double complete ends otherwise youll need 2 pairs of springs.the difference is smoothness. on bathroom tiles the gaps of grout used to bump steering off and loose speed but now it is better. also on a smooth surface (like my track) it hugs the road like a magnet.
shypo what sort of paint? i used humbrol metalic blue.
February 2, 2003 at 5:07 pm #41999
Shypo. I might take you up on that offer of installing the springs for me. You’ve done it before, I’m crap with models, and I don’t have the timne between making more tracks (some to sell on eBay) and having to learn 60 new songs for a band that’s just asked me to drum for them. :smiley16:
You have my emailI think, and if not, PM me your details.
Of course, if you break my Bit I’ll track you down and rip your ears off. 👿
DaveF! 👿
February 2, 2003 at 8:57 pm #41995
no problems Dave. ill PM u soon.
:shock:look how much gold you have!!!
February 3, 2003 at 3:44 pm #41963
Yeah, if only I could sell it at todays market prices. I could get some more BCG stuff. :smiley16:
DaveF! 👿
February 3, 2003 at 8:53 pm #41933
i would buy more than BCG, i would expand my empire worldwide.
keeps your eyes open in the next 10 years and i will be on the news for something….—-
February 3, 2003 at 9:18 pm #41925
You sent me your details yet Shypo? Hey Aaron, Derek… can I trust him? heeheehee.
DaveF! 👿
February 3, 2003 at 9:26 pm #41923
i was gonna do it the toher day, i’ll do it now. sorry man lol
of course u can trust good ol uncle shypo
February 3, 2003 at 9:27 pm #41921
Just don’t ask me to sit on your lap. lmao.
DaveF! 👿
February 3, 2003 at 9:29 pm #41919
back to springs. Zbeam how in the hell did you use lighter springs, those things are TINY
February 3, 2003 at 9:29 pm #41918
lol, you 2 are queer :blush:
57MHZ 2.6 Booster Trueno
February 3, 2003 at 9:37 pm #41908
how can a pimp be queer, that just aint right
February 4, 2003 at 5:50 am #41865
dont you get it barrellll, shypo is pimping daves ass to support his bit habit!.:shock:
wasted bout 15 lighters til i found one that was the same diameter. it was one of those peizo ones i think. zappy lighters, you know the ones. -
February 4, 2003 at 6:22 am #41866
those thing are cool… zap your tounge and it goes all tingly
February 4, 2003 at 2:31 pm #43770
or do it on your arm and it hurts, lighters are great fun, unless you are lighting bush fires 👿
And i dont want to know what shypo is doing to daves ass :blush:
February 4, 2003 at 3:28 pm #41835
Dave doesn’t even want to think about it. :dead:
DaveF! 👿
February 4, 2003 at 9:17 pm #41773
you guys are just twisted, u do all realise i am pimpin ur missuses’:evil::evil::evil::evil::evil::evil:
February 4, 2003 at 11:32 pm #41730
yeah suspension springs are good.
is there any micro rc’s out there that come with springs yet? -
February 4, 2003 at 11:34 pm #41727
Mini Z:D:D:D
apart from that not that i know of—-
February 5, 2003 at 4:51 am #41714
MINI Z. shypo i said micro, i meant 1/64th bcg scale.
February 5, 2003 at 5:00 pm #43698
What scale are MiniZ and what scale are BCG? I know one, but I forget which it is.
DaveF! 👿
February 6, 2003 at 6:41 pm #41654
mini z are 1/28 and bcg are 1/64 scale .. correct me if im wrong..
February 6, 2003 at 8:47 pm #41621
BCG are a deformed 1/70, Zip Zaps are 1/64
February 6, 2003 at 9:34 pm #41588
Thanks.
DaveF! 👿
February 6, 2003 at 9:54 pm #41582
oops forgot to add, larger wheelbase Z’s are supposedly 1:25
February 11, 2003 at 5:20 pm #41363
mini z is 1/32 scale not 1/24. 1/24 are those pre painted airfix nascar models. mini-z, audley and other tin cars are all 1/32.
1/70 scale? dont you mean 1/72 scale? thats military models. a 1/72 car is about half the size of a bcg, a panzer tank in 1/72 would be a little bit smaller than a bit.
bcg is sd (super deformed) 1/64th scale. its a japanese thing, i own a few sd gundam figures and their heads are equal proportions to their bodies!any body seen the customizable mini-z style cars?
they arnt kyosho and i saw them on toyeast. you can change the distances of everything from ride height to wheel base length. for different shells.
shypo does a moris have the same length wheelbase as chevy? they are both still 1:1 scale arnt they?
February 12, 2003 at 1:35 am #41335
sorry Z-beam you are wrong about the scale of Mini Z, they are 1:28 scale, if you adjust the H plate tho it can become a 1:25 or 1:24 becos the actual car is becoming differnt, the 1:1 metaphor is a very different one to the Mini Z one as 1:24 shells can fit on Mini Z with a small amount of modification.
a 1:64 car is a Zip Zap, BCG are smaller than Zip Zaps and ZZ’s claim to be 1:64 so the size differnece is a large one ths making the car a 1:70, a Panzer tank is ALOT larger than a car so not all model scales are catergorized
February 12, 2003 at 5:41 pm #41307
dude sd 1/64th is what bcg is. you may say alot but that doesnt mean you know everything.
the only reason you have such a high post count is cos of the crash…. and maybe your OBSESSED.zip zaps are LONGER not larger.
the point of the metaphor is sound, we are talking actual mini-z not some shell you can “make”. have you ever seen 1/70 scale? never in all my years have I. there is 1/72 scale.do you even understand scale? of couse scale is catagorized and equal! other wise no model would look right.my point is that the difference between true 1/72nd scale and sd 1/64 is huge, and obviously not just the difference between our 2 door bcg’s and 4 door zz’s
apologize shypo cos bcg’s ARE DEFORMED 1/64th
not “1/70th or deformed 1/70th” and admit you created the whole 1/70th thing.i dont relly give a poo about mini-z anyways. go ask a couple of train mod geeks and find out.
February 12, 2003 at 5:54 pm #41306
Ooooh. don’t get a train enthusiest talking about their hobby. It’s like Hotel California. once you’re in, you might never leave.
DaveF! 👿
February 12, 2003 at 8:58 pm #41289
Z-beam, no need to crack the **** dude.
im not gonna retype and get into a flame war over this but u have your opionions and i have mine, no matter what neither of us are gonna budge on our ideas. but jus becos “in all your years of a hobby” you havent seen a 1/70 car doesnt mean it doesnt exist, i havent ever seen a four leaf clover but they do exist, and sorry mate but zip zaps are larger in the width across, thats why they just float and they dont evn sit remotely well on a BCG.
so you are saying if a 1:24 shell fits on something and the wheelbase is extended and the chassis is wider then its not a 1:24, i have a feeling it is.
and the statement “do you even understand scale” is a very un called for statement, i may be younger than you but that doesnt mean i am not as clever, i may have a higher IQ or i may do very very well in school and i may be alot more clever than you, i am not saying i am i am saying that i may be.
ZZ’s come in 2 and 4 door and so do BCG, it doesnt make a difference in what style the car is
I am not apologising becos i believe i am right and i believe i have proven all my points, you may disagree but after you post i will close this or seperate this topic to avoid clouding this thread.any by the way i never said i knew evrything but i people tell me that i do know a fair bit about these litle cars, and my post count has nothing to do with the crash, i had 1100 or so posts before the crash, i got them back as did you so that was just a quite silly statement
February 15, 2003 at 7:05 pm #43666
the dimensions of a compact skyline are not to scale! all bcg cars have deformed features and there for ARE NOT scale models.
the japs use sd all the time, and the u.s doesnt like the “cutesy” look as much as japan. zip zaps are a bit wider and yes they are true 1/64th.
but that doesn’t make bcg’s a different scale shypo, it’s like fat and thin people, there both still humans.out of interest, which tomy shells have 4 doors.
also a ratio of 1/70th is mathematically unsound.what maths did/are you studying.apart from 1/10 cars all other scales ( i thought )are multiples of 8. e.g. 1/16, 1/32, 1/64, 1/72.
no need to censor my posts, it’s all in the name of freedom of opinion and democracy.
havn’t you ever found a shamrock!? i used to get about 3 every free period in year 12.
February 15, 2003 at 7:11 pm #41110
my gf reckons that the only numbers that divide into 70 are 10,5 and 7. shypo count the number of possibilties within 72……….. flexable number isnt it?
is there room in the pull backs for spring suspension and shypo do you reckon that the steering assemly is at all usable/modable?
February 15, 2003 at 8:55 pm #41104
firstly, all valid points and u give a good argument Z-beam.
secondly- tomy shells with 4 doors are the WRX, gloria, Evo and Voltz. i may have missed some but thats all i can think of.i am studying advanced 3 unit maths, i am 2nd in my class
but what about 1/24 and 1.28 scale cars man, they aint multiples of 8. well 24 is 3×8 but 1:28 isnt
in the pullbacks, there is no specific steering knuckles, there is a form of one but it wouldnt be worth adding springs to
the steering is worthless as its a push/pull system and it locks in each direction—-
February 17, 2003 at 5:22 am #41076
You spent your free periods looking for four leaf clovers?????……..cough..sad..cough.
The world is mine
February 17, 2003 at 9:04 pm #41046
um not quite Jamie, i actually hav spent alot of them sleeping or watching Jackass tapes in the library:smiley2:
February 19, 2003 at 7:01 pm #40874
i think jamie is talking to me shypo,
no actaully i was getting lucky with the cuties in the year below me. the clovers were just a part of spending hours close to nature…..enjoy it while it lasts, hell some of my freinds even did yr.12 over 2 years ‘cos of the “benefits”.
February 19, 2003 at 7:10 pm #40871
shypo 1:28 works cos it can be divided by many combinations. i used 8 as an example, the flexability is the key. 8 goes 3.5 into 28 anyways……
…..spring suspension should come standard, i’ve broke steering coil wires cos of their flimsy nature.
February 19, 2003 at 7:17 pm #40873
Shypo. PM me your address again. I’ll try and send the stuff off tomorrow.
DaveF! 👿
February 19, 2003 at 9:11 pm #40852
spring suspension should definetly come standard, its annoying having to spring all ur cars:angry:
dave: will do
February 20, 2003 at 4:37 pm #40773
does a booster have less room under the pcb?
has anybody made a dual cell booster? -
February 20, 2003 at 4:39 pm #40774
Springs should come standard, yeah. Surely it would be easy to fit for them in production.
DaveF! 👿
February 20, 2003 at 7:34 pm #40759
the standard bit by 2004 should have: dual 1/4 nimh sleeper, suspension, double layered COATED steering wires…….. booster chassis and controllers locally released, thats an idea JNH
I WISH
February 20, 2003 at 8:42 pm #43642
yes i have seen a triple cell booster and a dual cell sleeper boster car, doesnt look like theres less room.
z-beam: check out this http://www.toyeast.com/item.asp?page=search
and look under scale, there is 1/72 cars and almost any other calse u can think of:shock:
February 21, 2003 at 6:12 pm #40667Quote:1/70 scale? dont you mean 1/72 scale?
yep thats what i said. military (ARMY, tanks etc) useally use it but you can get almost anything some times.
February 21, 2003 at 6:18 pm #40666
not 1/70th though!:p:p:p i wrote “scale” in the search window and it came up with a heap of MECHA
February 21, 2003 at 8:26 pm #40658
dude 1/70 is right there, scroll down on the scale tool bar thingy and it it there
February 22, 2003 at 3:21 am #40625
those mechs must of distracted me just wait…
March 5, 2003 at 4:51 am #39982
Shypo – How’d those springs go? Was 1 spring enough to do both sides of a car? Did the car run ok afterwards? Got photo’s??
DaveF! 👿
March 5, 2003 at 8:45 pm #39962
jus swap the knuckles over, much easier so u dont hav to refit them:smiley2:
March 5, 2003 at 9:04 pm #39951
Huh. You’ve lost me. What do you mean Shypo?
DaveF! 👿
March 5, 2003 at 9:06 pm #39954
i mean just take the cyclona knuckles out of the car and put them in the BCG, they work the same.
and u dont hav to refit the springs to the knuckles and line them up and stuff.Dave: just got sum ZZ front knuckles and hav a rear axle coming…. just wait for ma 5 spokers
March 5, 2003 at 9:12 pm #39946
5 spokers, cool.
I was actually talking about the springs I sent you going onto the BCG knuckles. Or didn’t you bother fiddling around with those?
Do Cyclona knuckles come with springs fitted?
DaveF! 👿
March 5, 2003 at 9:17 pm #39945
sorry dave, i got a bit lost.
the springs u sent are a bit springy but are cool, they dont lower the car at all tho, only downside.cyclonas dont come stock with springs, i jus thought that the springs were put onto the cyclona and that the person (sorry i forgot who it was) and they fitted the springs to the cyclona, so u may aswell just swap around the knuckles, theyare the same.
March 5, 2003 at 9:19 pm #39944
yeah, not me with the cyclona.
so, were those springs I sent you any good? Are they worth me trying to fit them? If I do, do I remove the sway bar?
DaveF! 👿
March 5, 2003 at 9:48 pm #39940
jus chop the springs quite short and levae a little bit touching the upper part of the chassis.
fit them they are worth it.
u can leave the soft swaybar on but i dont think it makes a difference, my advice is leave it off—-
March 5, 2003 at 9:55 pm #39936
Thanks man. Is half a spring too long with those springs? How many winds past the taper did you use?
DaveF! 👿
March 5, 2003 at 10:32 pm #39931
man i stretched the springs a lil bit, i have about 4 circles so u can use like 1 spring for 2-3 cars.
half a spring will make ur car stiff as and wont be 2 good, will also jack up the front end and will prolly have a negative effect—-
March 5, 2003 at 10:35 pm #39930
What lowers the font end? Are there photo’s on the web of this, other than QFM?
DaveF! 👿
March 5, 2003 at 10:43 pm #39929
to lower the front end u will either hav to shave a new tab or use new tabs on the chassis, the chassis mod is prolly best with the supra as its a bastard to shave new slots into, trust me i ben there.
the tab lowering is on the admirals lair site for BCG and is about page 14 i believe—-
March 6, 2003 at 7:20 am #39900
watch it shypo… that was me who fitted a number of nanos/cyclonas and the clone steering dont fit into standard bcg without trimming, a bit to stiff eh?
March 6, 2003 at 9:07 pm #38278
the springs are a bit to stiff if u dont cut them.
i foiund cyclonas fitted fine tho:shock:—-
March 10, 2003 at 6:27 pm #37584
I’m still waiting for my springs to arrive. My only problem is that I don’t want it to lift the front end of the car, so I think that I will have to chop them down, but then the other problem is that it would pretty much be useless to use the springs.
March 10, 2003 at 6:39 pm #37587
if you remove the stock stabiliser/suspension bar you can keep it low and use springs
March 10, 2003 at 7:35 pm #37608
Really? interesting. I was under the assumption that it would raise the front end. pretty much all of my cars except for Bitzilla have the stabilizer removed.
March 10, 2003 at 8:27 pm #37616
depends on how stiff the springs are, if u have soft as springs then it wont jac up the front end at all
March 15, 2003 at 6:48 pm #37186
the clones that DO NOT fit (knuckles) nanoracers/fitchar-g and race master tornado.
all of the micro springs i’ve everseen available are all the same stiffness, what determines the ride height is the length of the spring.
all afx springs are like what shypo is sayin’ nice and soft and only just hold the chassis up.
the standard tomy suspension set (red) works amazingly well in combination with the perfect length springs.
for stiffer suspension you can wind the springs around each other.
