Steering Play
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › Steering Play
- This topic has 15 replies, 6 voices, and was last updated 23 years, 3 months ago by
jamiekulhanek.
March 20, 2003 at 4:15 pm #11661
Hey
Once i hopped up my mini z with camber blocks, new tie rods etc. It became apparent to me that thee was atleast 5-10degrees of slack in the steering setup. So like all good Jamie s, i fixed it :p
1). Open the servo case, and check the coupling between the 3rd servo gear and the Tie rod. If there is some slack, squeeze the 3rd servo gear coupler thingy with a pair of pliers to widen it. Do this until it has no slack, but can still move freely. Reassemble the servo.
2). A large amount of slack is due to the coupling between the tie rod and the steering knuckles. To fix, cut a piece of insulation tape 4mm x 12mm. insert it through the eye of the knuckle, so the sticky side is facing the inner side. Fold it over so the tape sticks to itself like a tab . Test it out and cut off the excess tape. I guess you could also try heatshrink on the tie rod coupling aswell.
3). There may be a bit of slack in the actual wheels. Tighten the nuts so there is no slack, but the wheels still spin freely.
If life is a waste of time, and time is a waste of life, then let s get wasted and have the time of our lives!!
March 31, 2003 at 4:57 pm #45634
Anybody noticed the slack??
Anybody tried fixing it??If life is a waste of time, and time is a waste of life, then let’s get wasted and have the time of our lives!!
March 31, 2003 at 11:00 pm #45641
i have never ever noticed that man.. could be sum race damage:question:
March 31, 2003 at 11:00 pm #45639
No, not really.
You sure this isn’t just result of impact damage? :dead:
April 1, 2003 at 6:17 am #45645
Nah, this was straight after i added hopup parts such as tie rods, knuckles etc.
July 1, 2003 at 2:52 pm #46104
same prob after i switched over to alu. them i stiched back to plasctic
July 1, 2003 at 6:16 pm #46105
what brand tie rod / knuckles did u use?
July 1, 2003 at 6:45 pm #46106
i used powerline racing then i used gpm and then i used megatech and all the same
July 1, 2003 at 6:52 pm #46107
Yeah think some of the parts loose tolerance. Mine has a small amount of play – I need to finish working on it and invest in some decent wheels and tyres though before I have to go to the lengths that Jamie has 😉
July 2, 2003 at 3:45 am #46112
I wanna know what jamie used so i can not buy that brand…
July 2, 2003 at 8:45 am #46114
pn racing have zero play all the outher brands have some play
July 2, 2003 at 4:47 pm #46116
I used topcad rods and knuckles, they are great once you get it all sorted out, a thin piece of heatshrink does wonders.
Oh and ive now broken my 4th servo gear :dead:
July 4, 2003 at 2:47 pm #46130
i use the metal servo gears there worth the money.
July 4, 2003 at 3:19 pm #46132
ive broken 4 servo gears sofar, i need to find where i can get metal gears.
July 10, 2003 at 1:15 pm #46182
http://www.towerhobbies.com has them use code 01V9 thats $10 off a $24.99 order or more
July 10, 2003 at 2:06 pm #46183
Do you think i can be bothered ordering one teeny gear from the USA…thanks anyway.
