The All-encompassing Mini-Z FAQ!
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Discussion › The All-encompassing Mini-Z FAQ!
- This topic has 12 replies, 5 voices, and was last updated 22 years, 9 months ago by
PandaBear.
January 14, 2003 at 4:08 am #11577
This is it guys… the start of a FAQ that will (eventually) answer all questions about this topic. Groundrulez:
Rule #1:- post only additions to the FAQ, not Questions or chitchat.
Rule #2:- post only Facts, not Rumours or Opinions.
January 14, 2003 at 4:13 am #44154
Main difference between Mini-Z (mZ) and PalmRunners (PR) is:-
Kyosho’s mZ is fully-proportional RC, whereas the PR is on/off control only.
Controls in fully-proportional are “analog” in that the power or steering is activated as much as you move the trasmitter’s control – giving you anywhere from nothing to full speed with everything in between.
On/Off control only gives All or Nothing.
January 14, 2003 at 4:15 am #44155
PR bodies and wheels are easily INTERCHANGEABLE with the mZ.
Depending on your LHS (local hobby store), some might find that buying a whole new PR kit is cheaper than buying new bodies and tyres for your mZ.
January 16, 2003 at 9:23 pm #44232
Do Not Touch antenna’s together (TX & RX) or you Will Fry Your Pcb.
Do Not allow Antenna to touch Engine, Alloy Engine pods, or roll shocks. (same reason)
Insulated Atenna Is the way to go.
January 16, 2003 at 10:20 pm #44239
Best to remove the batteries before performing any maintenance on your Z
Autoscales are also another cheap alternative to get new bodies and wheels (And you do not have any leftover controllers)
A soft earplug between the engine housing and the back of the chassis makes a relatively good damper
January 17, 2003 at 12:43 am #44265
The HPI micro RS4 Pinions (8-9t) are interchangeable with the mini z. The pinions are metal (not sure what) and are a solution to the plastic pinions which wear out.
The world is mine
January 17, 2003 at 12:48 am #44266
The front kingpins need to be lubed, a dry lube does not attract dirt so it does not need to be cleaned and relubed. This helps the suspension work more effectively
The world is mine
January 24, 2003 at 6:47 pm #44484
Spare gears are available for the steering servo if you strip them in an impact.
January 24, 2003 at 6:54 pm #44485
This is a great read if you want to fit some custom mZ bodies!
January 24, 2003 at 10:30 pm #44510
Try not to mix delrin and metal gears together… The metal ones will just shred the delrin ones 😀
February 17, 2003 at 11:10 pm #45089
Mini-Z come in either 1 of 3 different lengths (S/M/L), and 2 motor positions (low/high) to suit the different bodies.
Before buying a new shell make sure its either (1) the same as your current one or (2) you’ve got the right parts to convert. 😀
March 10, 2003 at 8:44 pm #45474
1:24 scale models can be custom fitted to mini Z chassis, using a custom H plate or O plate most designs can become yours.
March 11, 2003 at 8:30 pm #45477
MiniZ are “1/28” scale, so sometimes 1/24s might be a bit big so check width first.
Have also been told that some slotcar bodies might fit eg Fly, Scalextrix.
In all cases, you’ll have to engineer your own body mounting tabs etc of course.
