x speed motor and fets
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › x speed motor and fets
- This topic has 21 replies, 7 voices, and was last updated 22 years, 6 months ago by
PandaBear.
August 5, 2003 at 11:38 pm #11214
how fast does 6x fets with an x speed motor go roughly?…would it exceed 45 km/h?
August 6, 2003 at 9:16 pm #21673
I honestly doubt it.
even with a 10×2 stack i dont think it would. -
August 7, 2003 at 5:05 am #21682
maybe 19mph with really good cells the right gearing and useing no alu. parts
lets face it the x speed is a pos. no berings ect. my little $10 plasma dash eats the x speed alive so dus my ultra dash and that was only $5
August 8, 2003 at 7:23 pm #21772Quote:how fast does 6x fets with an x speed motor go roughly?…would it exceed 45 km/h?
Nah sorry mate, try buying a tamiya plasma dash if you want speed.
An x speed with 6×2 fets would be no slower than one with 10×2 fets.
It only matters how many fets you have when you start dealing with big power, however an upgrade to 2×2 or 3×2 will see more power and speed from an x speed motor, only because the standard FETS are McBullsh*t and can only JUST handle the x speed motor.
With A fet mod, 9-tooth pinion, and x speed, expect around 30km/h.
August 8, 2003 at 8:05 pm #21784
only way a x speed will be fast is if ya kick the car, its a 50 turn its like a 1.8 in a real car and the plasma is like a 5.0 and the orion big block is like a 6,000 hp eng outta a top fule dragster.
x speed is about $25 usd the plasma is about $12 usd and if you dont wanna spend alot get a ultra dash for about $5 usd and its alittle slower than a plasma dash but alot faster than a x speed. just changed the brushes in all but the plasma
August 9, 2003 at 12:46 am #21808
is that motor for mini z?
the tamiya plasma dash ? -
August 9, 2003 at 1:55 am #21810
and how much fast does it go wid a 6x2fet mod?
August 9, 2003 at 7:22 am #21812
the plasma is a way better motor than any mini z motor. it was made for small 4wd cars that ran on 2 aa batt’s in a track but there the same size and seem to work better in mini z’s.
6X2 will be alot faster than stock. on my z im running 20X2 and i just put the fet stacks on the pcb cover. if you wanna do somthing more than 6 i found out a good way on how to hook them up
August 9, 2003 at 10:42 pm #21825
so wats it called?
does any shop in australia sell it? -
August 10, 2003 at 8:43 am #21828
they might there tamyia moters just ask the shop if they sell tamyia mini 4wd parts and if they do the biggest you can use without fets is a hyper dash and you need 2X6 fets for a plasma dash.
if they dont sell it just go to http://www.towerhobbies.com and search up “mini4wd” and get the part number from the moters then call a few local shops and see if they have or they can order them
August 10, 2003 at 3:29 pm #21833
So let me get this straight in my head.
Tamiya Mini4WD motors are:Hpyer Dash (slowest of their ‘hot’ motors)
Ultra Dash (mid-range)
Plasma Dash (Top range – best!)I’ve seen these in most online stores just never knew what order they went in for performance.
August 10, 2003 at 5:04 pm #21840
heres from what i remember there might be a few i forgot
jetdash i think its green
torq tuned
atomic tuned gray endbell
mech dash
hyper dash red end bell
ultra dash black end bell
plasma dash opend gray end belli’ll check up and get a full list and post there spec’s in a new trend named mini4wd motors
August 10, 2003 at 10:24 pm #21842
Cool. Sounds like there’s more motors int he range than there are burgers at McDonalds 😉
August 11, 2003 at 11:19 am #21851
only bad thing is there brushes suck. so you can swap them for the stock brushes rom the mini z or buy the pn racing brushes. the plasma has nice brushes
August 31, 2003 at 10:15 pm #36221
try…http://www.rcmart.com…they shipp ww..and the currency can be changed….mini z parts are cheap!!
September 1, 2003 at 4:17 pm #36241
This seems to be the current lineup…
ITEM 15131 (GP131) Mach-Dash Motor
ITEM 15133 (GP133) Rev-Tuned Motor
ITEM 15134 (GP134) Torque-Tuned Motor
ITEM 15186 (GP186) Plasma-Dash Motor
ITEM 15215 (GP215) Atomic-Tuned Motor
ITEM 15225 (GP225) Touch-Dash Motor
ITEM 15256 (GP256) Hyper-Dash 2 MotorAnd I’ll be darned… they DO sell brushes for the Plasma.
“94387 AO-1009 Brush Holder Set for Plasma-Dash Motor”
But its “Japan Only”… :dead: -
September 1, 2003 at 4:51 pm #35717
For the price of these babies you may aswell replace the whole motor rather than buy brushes.
September 1, 2003 at 4:51 pm #36019
September 1, 2003 at 5:55 pm #35725
Can’t say I’ve used them a lot, but the one stuck in the Beat Magnum does leave quite a bit of carbon filings at the air-vent. (I’ve cut airscoops pointing into the motor for cooling, this thing sucks 4A from the AAs…!)
Probably only have done 15-20 runs on the track and the brushes in that one are about 1/2 gone.
But yeah, don’t know how much they charge for the brush kit… but @ $20ea the motors aren’t exactly cheap.
Dare say a Mini-Z with 4.8V will work the motor even harder. blackeye:
Now if someone tells me they’ve got comm lathes for 130 motors… WHY won’t I be too surprised??! :evil::evil::smiley2:
September 1, 2003 at 5:55 pm #36027
September 1, 2003 at 6:44 pm #35728
LOL looks like this motor ain’t gunna last long.
September 1, 2003 at 6:44 pm #36030
