Home made suspension…….
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Home made suspension…….
- This topic has 18 replies, 7 voices, and was last updated 22 years, 7 months ago by
SurfmyStrat.
April 18, 2003 at 5:08 am #10380
Fellas, I had a rare brainstorm at work and raided some storage cupboards and found some really old DDS tapes(4GB to 8GB sized tapes used to backup data from servers). At first I was thinking that maybe I could pull apart some floppies and use the spring from them. But then I thought, why not try the DDS tapes. And would you believe it the springs in these mofo’s are perfect!
So here’s what you need to do, first source a tape!
Then pull it apart and look for two springs sticking out of the plastic backing. Refer to where I have the needle nose pliers pointing for the springs, you can see them but they’re a bit fuzzy.
Below shows the springs removed from the DDS tape unit and placed next to a clone wheel so you can see the size of these. A little bit long but otherwise purfect!
One third along the length of the spring the coil changes and becomes compressed (as you can see in the previous pic). I cut this portion off since it’s too long anyways…… Below shows the springs cut to a good size.
Obviously you need to remove the cover of the steering assembly to be able to put the springs on. Notice the clearance given by the springs to the pivot to allow the cover to sit back on without overcompressing the spring and therefore inhibiting steering ability.
And your done………………
So all you fellas who work in IT get those DDS tapes now before they disappear!
:approve:
April 18, 2003 at 5:12 am #33800
I might have a few spare :). If anyone is interested PM me.
Cheers,
April 18, 2003 at 8:04 am #33801
Hey Ph2t,
how is the car’s handling now ?
Ciao
Efarel -
April 18, 2003 at 10:03 am #39717
thats a great idea, also i wonder if one of those video camcorder tapes would work the 8mm ones, they look about the same size as the DDS tapes. Ill look in one of mine and tell you.
49 MHz Honda S2000
2 Clone Mazda RX7’s
Lots of spare stuff… -
April 18, 2003 at 2:06 pm #33748
Well done ph2t for finding those. Not exactly accessible by your average joe but a good brainstorm nontheless.
I have another topic for you to have a brainstorm on….rear suspension.
Got any ideas?:)uA
April 18, 2003 at 2:54 pm #33749
im not ph2t, but i thinked he would agree that that would envolve a lot of surgery and chassy modifications.
you are currently at: http://www.ausmicro.com
April 18, 2003 at 4:34 pm #33750
Nice work Ph2t… shame I destryoed all those tapes when i was little…:shock:
April 18, 2003 at 6:01 pm #33759
They ride well. Biggest difference is that when I hit a bump the car doesn’t change direction as great as before, turning is still the same I think, didn’t notice much . I’m experimenting with removing the stabiliser bar as well and trying slightly stiffer springs.
I want to try the full wheel mod for the front section using the rear wheels from a clone to see if that improves steering and overall handling as well.
One tip though, if your magnet falls out of the arm it’s encased in make sure you put it in the correct way. I had to stuff around for an hour wondering why my steering was so crap 🙁 , put the magnet in the right way and all is sweet again. 8)
The Hi-8 tape mechanism is similar, I have only 3 tapes that my wife and I use for our camcorder so I ain’t gonna rip them apart:smiley2:. The DDS tapes were gathering dust in a storage cupboard at work, hence the opportunity. Let us know how you go SurfmyStrat.
Micro, if ya want a pair just PM me. As for rear suspension I dunno. I believe you would need to remove the whole rear end to make it happen since you would need to keep the motor/gear/axle assembly together. If the car had a differential (yeah right!) axle setup you might be able to do something but I dunno.
Hmmmmmmmmm…….
April 18, 2003 at 7:50 pm #33769
for the rear suspension you would probably have to set the cars rear up kinda like a Mini Z with a H plate connectiing both halves of the chassis. otherwise its gonna be kinda hard.
Ph2t: when you out the steering cover back on does your car sit higher at the front?—-
April 18, 2003 at 8:18 pm #33777
A little Shypo, but not much man. I’m gonna try some more tensile springs to keep the front end up higher. Too much pressure on the wheel knuckle kills the steering though….
April 18, 2003 at 8:21 pm #33780
Ah ok. with the springs i fitted to a couple of my cars (chopped AFX springs) my car barely sits up at all. if anything its a tad lower. yeah i agree with the strong springs.. i use tightly strung springs for a drag car i used to sue so it wouldnt turn when going down the strip.. the little bit of lift is good because then the springs do make a differnece but with a bit 2 much the whole steering characteristis are destroyed..
April 20, 2003 at 3:53 pm #33670
ph2t, i got a pair of STIFF springs out of a lighter and they hold the bit steady. i have done the fullsize wheel mod combined with afx suspension on my camo Bb:
http://groups.msn.com/bitchargoz/paintingmods.msnw?action=ShowPhoto&PhotoID=50
the handeling was so improved once i removed the stabilizer bar, also you can wind multiple afx/dds springs together to create higher degrees of tension. have fun tuning!!!
April 20, 2003 at 8:35 pm #33650
With the lighter springs Z beam didnt u find them a full on squeeze to get over the knuckles, I know I did…
April 22, 2003 at 9:07 am #39291
excellent idea PH2t… if you have the tapes to spare great.. i went to the hobby shop and bought slot car springs… 4 of them for 1.89. there were about 15-20 different sizes and spring rates, all of which would fit the bit steering knuckle.. im using them on my monster bit right now…
April 23, 2003 at 5:57 pm #33183Quote:With the lighter springs Z beam didnt u find them a full on squeeze to get over the knuckles, I know I did…
i found a larger than the nuckle pin spring and stretched it so it was perfect diameter. the ones that are too small will always be too small.
April 23, 2003 at 10:03 pm #33159
Oh ok.. cos i was wondeirng how the hell you got em on.. i was havin so much trouble.
April 24, 2003 at 2:56 pm #33136
yea, i just took apart a Sony Hi8 MP video cassete for the camcorder. It does have a spring in it but it is to large
. But as with most other tapes it has some good substitutes for a steering spring.you are currently at: http://www.ausmicro.com
April 24, 2003 at 3:05 pm #39689
Good stuff surfy, nice to know. Is is too large in diameter or in length? ’cause you can always take a pair of clippers to it if it’s too long (as I mentioned in the begining of the thread)
April 28, 2003 at 3:58 pm #32669
if a springs diameter is to big u can strecth it to make it less phat. have a go smurfy
